Author Topic: Low, LOW mpg  (Read 20413 times)
Re: Low, LOW mpg
« Reply #15 on: January 24, 2012, 01:45:31 pm »
Actually the 4.3L/TH400 was common in the later years as the TH350 wasn't offered, and if you didn't want a overdrive trans you could get the TH400 with the 4.3 and the 5.0L.
Offline bryanedp9
Re: Low, LOW mpg
« Reply #16 on: January 24, 2012, 06:36:49 pm »
I try to be pretty easy on the pedal, and it does like I'd imagine it should city driving, but I put cruise on at 65 usually on the commute. That's when it starts to tank. Picked up a bike today so hopefully I won't be in a rush to get it all taken care of.
Offline bryanedp9
Re: Low, LOW mpg
« Reply #17 on: January 25, 2012, 03:45:12 pm »
Okay, at about 40mph in 2nd it was begging for another gear, so I went to D and third came right in. Can I discard trans problems now and go straight to fuel/exhaust or could it still be a gearing thing?
Offline bryanedp9
Re: Low, LOW mpg
« Reply #18 on: January 26, 2012, 09:58:51 pm »
Okay, I have a couple ideas as to low mpg so far, so chime in with input. I haven't yet had a look at the intake, but this is what I know:
1) What I think is the charcoal canister has rotted lines. I'd imagine that's setting me back. If so, what size hose do I need?
2) Tank selector valve is either burnt out or has a wiring problem. I've only been able to use the right side tank since taking ownership. New selector switch did nothing to help. This might relate to...
3) I think my fuel pump is going. After coasting downhill, it might sputter before the uphill climb and sometimes doesn't want to start at all unless I tap the framerail in that area.
So any advice you have pertaining to this any other causes of low mileage, please let me know. It's a family vehicle but the money for pumps and an exhaust and whatnot might put me into sell mode instead.
Offline 87454westernhauler
Re: Low, LOW mpg
« Reply #19 on: January 26, 2012, 10:21:44 pm »
fom what u are saying and from my personal exsperiances with TBI systems, i would say that your biggest problem is not having a muffler for back pressure. My dads 87 454 was getting about almost 16-17 mpg and about a month ago the mufflers fell off and it is lucky if it get 10mpg. what i would do if u are trying to go cheep is stick a cheep muffler on it. how much of the exaust is left on it?
79 gmc c20 350 th350
78 k1500 4x4 350 th350
Offline bryanedp9
Re: Low, LOW mpg
« Reply #20 on: January 26, 2012, 11:09:47 pm »
It has one of those flexpipe deals from the headers. Someone (probably Pa) used bailing wire and a U-clamp to keep the muffler on so I lost it.
Re: Low, LOW mpg
« Reply #21 on: January 27, 2012, 04:05:27 am »
most states are ok if you have the exhaust run past the cab so put some straight pipe in then the muffler. unless you want to run the whole thing where you will see the most back pressure is a cat. but its illegal to use used cats from another vehicle so i think you would have to buy them new
Offline bryanedp9
Re: Low, LOW mpg
« Reply #22 on: January 27, 2012, 01:20:56 pm »
What about dual glasspacks behind the cab? Would that give reasonable backpressure?
Re: Low, LOW mpg
« Reply #23 on: January 27, 2012, 04:03:46 pm »
it should, would be better than nothing. that is what i had on our 87 454 before they rusted out and fell off. turbo muffler are cheaper and quieter.
Re: Low, LOW mpg
« Reply #24 on: January 28, 2012, 10:31:17 am »
glasspacks do give you something but not not a muffler will do. i love load trucks but wouldnt want to hear it everyday
Offline bryanedp9
Re: Low, LOW mpg
« Reply #25 on: January 28, 2012, 10:41:38 am »
Alright, so backpressure is needed and a clean intake. What about the weak fuel pump?
Re: Low, LOW mpg
« Reply #26 on: January 28, 2012, 01:17:53 pm »
sound like u have a loose ground if u have to wiggle or tap tank.
Re: Low, LOW mpg
« Reply #27 on: January 28, 2012, 01:24:38 pm »
Anything that is a problem to how the truck is supposed to run normally is going to affect it.  If you have to tap/hit/beat the side of the frame to wake up your fuel pump than it is time to replace it.  Could be a bad ground but more than likely it is in need of replacement.  I used to know of a guy who had a 4.3L with a 5 speed in a full sized 1990 extended cab C1500 and he was around 22mpg.  My $.02
Re: Low, LOW mpg
« Reply #28 on: January 28, 2012, 01:51:31 pm »
yah. now that i think about it, it could be a bad fuel pump.
Offline bryanedp9
Re: Low, LOW mpg
« Reply #29 on: January 28, 2012, 03:08:41 pm »
Ugh, I need a job guys. Or better bike weather.
Should I drop the tank or lift the bed for a pump replacement?
