Author Topic: Brake problem  (Read 45138 times)
Offline 1979C20
  • Kyle Taulton.
Re: Brake problem
« Reply #15 on: February 21, 2012, 12:28:51 am »
Alright. My mom bought the booster/master combo for me last week. I got it swapped out the same night. Stops even better than before it broke. But, Now I have some other issues to address. Need to find an oil leak, and I really need a clutch. Or at least a throwout bearing. Its making quite a bit of noise.
Re: Brake problem
« Reply #16 on: February 21, 2012, 06:28:44 pm »
      And on and on it goes, where it stops nobody knows, sounds familiar huh ?   :D
Offline 1980c10
Re: Brake problem
« Reply #17 on: February 21, 2012, 07:58:55 pm »
I know its a little late for it now but for others here you could have swapped in a newer booster and master since you bought them together. I have an '85 version on my '80. The booster is a little larger in size and the master is newer style plastic housing. I don't know if it actually has an advantage but I have a master that the cap doesn't leak and thats enough for me.
Offline 87454westernhauler
Re: Brake problem
« Reply #18 on: February 21, 2012, 08:07:01 pm »
the newer master cylinders are much easyer to check the fluid in and fill. Personaly from my exsperiance, they  also seem to last a lot longer than the old steel ones. :o
79 gmc c20 350 th350
78 k1500 4x4 350 th350
Offline cheeba_c10
Re: Brake problem
« Reply #19 on: March 19, 2012, 04:05:02 pm »
i'm having the same issues with mine right now.  i think i'll try and order the new booster and master instead of buying the one "meant" for my truck.  thanks for the info
always live life following the 6 P's:
Proper Planning Prevents Piss Poor Performance
1980 C10 Bonanza
