Author Topic: Help.? anyone?  (Read 10877 times)
Re: Help.? anyone?
« Reply #15 on: February 18, 2012, 07:01:20 am »
  What do you mean your starter backs off and spins after a few seconds?  Are you saying you have a starter problem too?
     If you overheat a starter the bendix will not engage fully, sometimes you have to cool it down before it works right.  It is also a good way to burn out your starter too.
Offline Low82C10
Re: Help.? anyone?
« Reply #16 on: February 18, 2012, 01:16:57 pm »
i just did what you asked, i pointed rotor to #1, got the mark on 0 and turned it CCW and it started moving at about 1/2" so its around the 4 or 5 on the mark
Online bd
Re: Help.? anyone?
« Reply #17 on: February 19, 2012, 09:26:12 pm »
That 1/2" of rotation translates to about 8 degrees of timing.  If you wound up on the 4th or 5th mark (each mark is 2 deg), that confirms 8 - 10 degrees of looseness in your timing chain.  If you're certain on the stabbing of the distributor, then the engine may have jumped time.  Even w/o jumping a tooth, a timing chain that loose could have caused all your original symptoms.
