Author Topic: What a HOT mess...  (Read 16524 times)
Offline Sodium Duck
Re: What a HOT mess...
« Reply #15 on: February 26, 2012, 05:11:47 pm »
New temperature sender and gauge installed. Truck warms right up to 190 with no problems. The only thing I noticed was when stopped at a light, the temp would drop. But that's probably because I had the heat on full blast to keep my buns warm. So overall, score one for me! Thanks for all the help everyone!
But... hahahaha, when I drained the coolant this time, it did have a brown tint to it. Took it inside, under the lights, in a clear container. Light brown. Not sure if it's rust from the radiator, or oil. Will keep an eye on the coolant levels. Also, when it warms up outside, I'm going to change the oil and check it out, too.
1985 K10, corporate 10-Bolts front and rear, 6" lift, 35's, 305, auto, longbed.
Offline 87454westernhauler
« Reply #16 on: February 26, 2012, 05:46:39 pm »
some one might have put stop leak in it at some point in time, or it could be rust.
79 gmc c20 350 th350
78 k1500 4x4 350 th350
