Author Topic: steering column swap help  (Read 47541 times)
Offline gto109
Re: steering column swap help
« Reply #15 on: March 06, 2012, 06:54:47 pm »
After smacking my head off the side of the hood I added the step of take hood off.  I am replacing the hood on Friday anyhow.  I now have a nice tight column and turn signals again.  Still have no hazards or horn but that's another story.  Only thing I don't like about it is the horn button says GMC & mine is a chevy.
85 Scottsdale k-10 305 700r4,
86 Trans Am 305 350th
06 Dodge Ram daily driver
Offline thirsty
    • Suitor's Garage
« Reply #16 on: March 06, 2012, 07:11:02 pm »
The horn buttons aren't the same on those two columns? I thought you could just swap them out.
Offline gto109
« Reply #17 on: March 06, 2012, 07:22:25 pm »
Old style vs new.  the column is out of a 90 or 91 suburban
« Reply #18 on: March 06, 2012, 07:59:30 pm »
eBay, see them on there all the time
Offline gto109
« Reply #19 on: March 06, 2012, 09:24:33 pm »
Just look under horn cover for 90 suburban?
Offline gto109
« Reply #21 on: March 06, 2012, 09:47:26 pm »
Thank you for the links.  I bought the second one.  Its in the same state I should have it by Monday at the latest.
« Reply #22 on: March 06, 2012, 09:51:28 pm »
Awesome, took seconds to come up with those links.  After I saw the first one, I came back with the second as I remembered it had the notches on it...
Offline gto109
« Reply #23 on: March 06, 2012, 10:22:40 pm »
Thank you for all your help Zieg.  I don't think I would of had this done as fast as I did without the perfect directions.  I think I spent more time running for stuff I didn't have then I did working on the truck.
« Reply #24 on: March 08, 2012, 04:29:47 am »
     Isn't that always the case, seems like you always spend more time on running around getting parts or doing research then it actually takes to do a project.  Oh well I guess that is half of the battle.
Offline werewolfx13
« Reply #25 on: March 11, 2012, 12:44:27 am »
Very accurate write up. Did a similar swap in my truck last year. I rebuilt a column I bought from a member on this site, and swapped it out. All in all, 6 hours from the start of the rebuild (including the 45 minutes I spent running after new ball bearings..twice...) til I had the new column in. 3 hours is about right for the install time.  Didn't need to remove the hood though...
Chris
'83 Chevy c10 Silverado SWB
