Author Topic: Cooling fans  (Read 13439 times)
Re: Cooling fans
« Reply #15 on: March 08, 2012, 04:39:29 am »
Cheers Beastie,
All I wanted was was an easy install to fire up the fan. I didn't want to wire it permenantly or off a switch in the cab, I'd forget to turn it on!
Andy
      Sounds like to me a thermostat type is what would be best for you.  Once you get it hooked up, it does all the work for you and you can enjoy your ride knowing the fan will do it's job when needed.
Offline 1980c10
Re: Cooling fans
« Reply #16 on: March 12, 2012, 05:03:12 pm »
With my adjustable thermostat if you dial it all the way back; it has a detent and will stay on all the time. So you would by default have at least an underhood switch.
