Author Topic: Bought a 14-bolt today, what have I gotta do to run it?  (Read 19726 times)
Offline Kevin108
Re: 10 bolt?
« Reply #15 on: January 28, 2003, 04:07:00 pm »
Talking stock axles, the ring gear bolts, the spider gears, and the pinion diameter are all larger and the R&P is stronger on a 10-bolt.  Stock carrier and spiders on the D44s are notoriously weak.  Only place a D44 is stronger is the axle housing, 1/2" walls instead of 1/4" or .313" walls.  From they're out they're nearly identical.
87 Silverado 4x4 Longbed Pickup
My Mods | Truck Pics | Kevin108@PavementSucks.com
Maker of 43 point turns!
Offline Eric 85K10
Re: 10 bolt?
« Reply #16 on: January 28, 2003, 08:37:00 pm »
How much would you want for wheels Kevin?
Offline Kevin108
Re: 10 bolt?
« Reply #17 on: January 28, 2003, 09:53:00 pm »
No idea.  I haven't checked to see what they go for new to determine what they're worth.  Just for the solid aluminum I think they're worth $10 a piece but I'd probably want a little more for them. :-) I won't be ready to get rid of them until this summer though.
Offline Eric 85K10
yeah
« Reply #18 on: January 29, 2003, 12:35:00 am »
thats cool I wouldn't even have enough for shipping tell summer :)
I wish I was looking for 8 lug rims though. But investing in 3/4 axles is a bit much for me :p
Offline Kevin108
Re: yeah
« Reply #19 on: January 29, 2003, 04:06:00 pm »
It's not gonna be a really cheap setup but after I shredded a $250 locker and a set of spiders I knew I was gonna have to put some money into an axle.  I feel a lot better about building a bullet-proof 14-bolt than I do putting any more money into the little 10-bolt though.  I'll at least have something to show for it when I'm done.
Offline Eric 85K10
Re: yeah
« Reply #20 on: January 30, 2003, 01:21:00 am »
well thats true, a 14-bolt is worth the money to build up
Offline crazyk1le
i got a 14 bolt
« Reply #21 on: October 22, 2003, 10:56:00 pm »
hey guys i'm not a 4x4 guy but i do have a 14 bolt 3/4 ton axle in the truck i plan on lowering and putting a big block in can you build this rear ends and whose a good company to go through are they a good rearend for what i want to do will be a street truck with some towing
