Author Topic: Another stepside build/restoration  (Read 52446 times)
Offline TimberwolfFXDL
Re: Another stepside build/restoration
« Reply #30 on: June 17, 2012, 09:56:57 pm »
got inspired to do a little work today, despite the heat...
Offline sonicbluezx3
« Reply #31 on: June 19, 2012, 04:40:39 pm »
Lol a little work? Wow. Nice job. Looking forward to see the end result!
1986 Chevy K10 w/ 1983 Cab, 1984 Bed, 1987 Doors and a 6.2 Diesel Swap w/ 700R4 Trans. Truck body completely re-done between 2010 and 2012.
Offline thirsty
    • Suitor's Garage
« Reply #32 on: June 19, 2012, 05:05:42 pm »
It coming together and coming apart at the same time! :o
Keep up the good work.
« Reply #33 on: June 23, 2012, 06:01:44 pm »
Found a motor for it.  2002 350 crate motor with 40k miles that will get mildly modded and transplanted into my the truck. I'll sell off everything else of value (TBI setup, wheels, tires, transmission, transfer case, front and rear axles) and take the rest to the local scrap metal place.
« Reply #34 on: June 28, 2012, 07:11:27 am »
Anyone know where I can find some front rotors drilled for 6 lug?  or would it be easier just to have mine welded and redrilled?
« Reply #35 on: June 28, 2012, 10:56:35 am »
Why are you wanting 6 lug?  The rear is 5 lug, are you going to change it also..
« Reply #36 on: June 28, 2012, 11:15:23 am »
the chassis I bought is a 4wd and has a real nice set of wheels I'd like to use.  I can swap the rear axles (both trucks have 10 bolt rear), so I'd just need to figure out the front
« Reply #37 on: June 28, 2012, 11:37:22 am »
The aftermarket supplies 6 lug discs, check with http://www.gmcpauls.com/Brakes&Steering.htm
« Reply #38 on: October 01, 2012, 09:35:44 am »
Been a while (again) since I've updated.  Not a lot has changed, other than I was able to secure a good sized workshop.
I did get the firewall cleaned ("aircraft remover" works WONDERS on that tar and goo, and a wire cup brush on an angle grinder finished it up nicely), and the whole front fame and suspension powerwashed and sprayed with a rust converter primer.  Working on the power steering conversion, but I can't seem to separate the old pitman arm from the tie rod, despite my best efforts with a fork and hammer.
Still deciding on a motor.  I have a 2001 roller block than is fresh from the machine shop (.030 over), and I picked up a 454 with 58k miles from a motorhome.  Has 781 heads, so that's a plus, but the compression on these mid 70s motors is abysmally low, and getting it back up to a decent range for power making is going to either require a new set of pistons or shaving the heck out of the heads.  Neither option is something I am looking forward to... the 350 needs pistons as well, and some heads (sold my good vortec heads due to a low-cash moment) etc
as far as the transmission, I still have the 700r4, but a th400 came with the 454.  Both have their pros and cons... so there's another decision :lol:
« Reply #39 on: October 01, 2012, 07:02:47 pm »
« Reply #40 on: May 14, 2013, 03:02:42 pm »
It looks like this now:
Offline 81_Chevy
« Reply #41 on: May 14, 2013, 03:14:21 pm »
is that a big block i spy?  8)
« Reply #42 on: May 14, 2013, 03:16:33 pm »
indeed. from a straight 6 and saginaw to a 454 and th400 :)
Offline frotosride
    • WFO CONCEPTS
« Reply #43 on: May 14, 2013, 05:46:04 pm »
Like the build. I have always liked the stepsides every since I was a kid and first saw that movie called "tremors".
I bet that your right foot is liking those new extra cylinders but gas tank not so much..
Offline 79brent
  • Shake and Bake!
« Reply #44 on: May 24, 2013, 04:32:04 pm »
You guys in different states are so lucky! I wish I could make my motor look like that but cali sucks. I have miles of vacuum lines under my hood! Its ugly as heck! Nice truck though 8)
1979 Chevy C10 Silverado package. 350/350
"Lifes a garden DIG it"
