Author Topic: 2 inch wheel spacers installed wheel looks "off"  (Read 34221 times)
Offline Thundergun
Re: 2 inch wheel spacers installed wheel looks "off"
« Reply #15 on: March 06, 2016, 08:46:21 pm »
Any updates on this 'bowing' issue of the rear axels?
I'd like to get some spacers for my rear. I installed a suburban rear end/axle, and it's noticeably shorter length wise. I'd like the wheels to stick out a little bit. But this issue sounds terrible.
1985 K10 Shortbed, 6" Superlift, 33x12.5x15" tires, 100% bad, '87 fuel injected 350 (i think)
« Reply #16 on: March 07, 2016, 01:47:25 pm »
im going to add this, im not a expert on this but theres a such thing as hub centric wheels and lug centric wheels. most oem wheels will fit snugly over the hub of the axle and the lugs just hold the wheel on vertically while the hub holds most of the weight. if you install a spacer you are essentially turning your hub centric wheels into lug centric and putting all the weight on the lugs. i dont know if the problem but to me it makes sense to me and if you turn the spacers into hub centric spacers then it should fix the problem
