Author Topic: Heads  (Read 16711 times)
Offline Korndiggity
Re: Heads
« Reply #15 on: July 01, 2012, 11:49:08 pm »
I think for a mild build, they are plenty. There were a few different intake runner sizes available, I took the 'sufficient' route. The 350 I have has mild dish top pistons. So, timing and compression isnt that much of a concern. Now, I can pretty much build a strong shortblock with variations in cams, and I dont really have to worry about modifying the top end anymore-for the most part. But to answer your question, yes. I could drive the truck every day-it runs great. I once had a 70 El Camino-I ran the fuelie 2.02 heads with a mild cam(It was the 350hp 327 cam from the late 60's; .447/.447???), headers and a B&M stall converter. I ran 13.99s on street tires and 87octane. I bet you could bolt on a solid amount of hp by just using a similar set of heads with no other real major mods. Now if you have headers, and duals...the gain would be that much more.
84 Chevy Scottsdale SWB 4x4; 4" suspension lift.
Offline 454Man
  • Why Race?
Re: Heads
« Reply #16 on: July 02, 2012, 07:59:00 am »
Great! Are they predrilled for assesories? (Three screw holes on the ends of the heads.
Offline Korndiggity
Re: Heads
« Reply #17 on: July 02, 2012, 10:27:26 am »
Ya, everything goes back right where its supposed to-A/C, Alt...the usual accesories. I believe it even has the vortex style intake bolts(the straight down ones). I would have to double check. Google Skip White Performance. That would be able to tell you exactly what they will accomodate-
Offline 454Man
  • Why Race?
Re: Heads
« Reply #18 on: July 02, 2012, 10:35:31 am »
Thanks!
Offline DTrain
  • 1984 Silverado
Re: Heads
« Reply #19 on: July 16, 2012, 08:05:57 pm »
Have you guys heard of Muskegon cams and lifters? There is a guy selling a whole brand new cam kit on Craigslist locally at an awesome price. I have never personally heard of the company. Also he said it is a 274. Is that a good upgrade size?
Offline muddpuppy01
Re: Heads
« Reply #20 on: July 17, 2012, 10:20:59 pm »
when I rebuild my 350 I was looking at a 268 cam with vortec heads with new springs to get a little over the .480 lift limit 274 might be a bit much with stock heads and springs
