Author Topic: Lifters / Valve adjustment question  (Read 9012 times)
Offline Jason S
Re: Lifters / Valve adjustment question
« Reply #15 on: July 28, 2012, 01:31:15 am »
Is the engine recently rebuilt, have new heads, solid tappets/lifters?  Did the ticking start out of the blue? Do you have a new exhaust system on the truck?
For hydraulic tappets/lifters, it looks like the other postings have covered things pretty well.
I think I read that you have manifolds.  If your still looking at the exhaust, besides checking the manifold to block you might take a look at the manifold to exhaust pipe.  If the donut is cracked, deteriorated or the connection is not tight you could get a ticking noise.  A leak from any joints in the exhaust, especially if there are slip joints on the exhaust system.
« Last Edit: July 28, 2012, 01:35:02 am by Jason S »
Offline Fairlane514
« Reply #16 on: July 28, 2012, 09:21:27 am »
One question I forgot to ask, does the ticking sound speed up and slow down when you increase and decrease rpms?
