Author Topic: engine experiment...take a shot.  (Read 13135 times)
Re: engine experiment...take a shot.
« Reply #15 on: August 01, 2012, 09:26:59 pm »
Depending on the bottom end (I believe the 260hp motor only had 8.6:1 CR) you are not going to see 400hp on that motor, as most top end kits require a decent bottom end to make their predicted power as bd pointed out and with the listed cam setup you are going to need a good size stall.  You need to plan the build around the end result you are hoping to achieve.
Offline BIG CHEVY
  • FOLLOW ME,,,, ILL TRY IT.
« Reply #16 on: August 01, 2012, 11:20:12 pm »
Sorry guys for the uninformation. This is ending up in a camaro with a Borg Warner 4 speed. I can change Pistons. Just don't wanna change rods and crank.
Offline 1980c10
« Reply #17 on: August 02, 2012, 05:39:07 pm »
Your rods and crank will work fine. (If you were asking)
