Author Topic: Hesitation/bog Problems on my 86  (Read 24394 times)
Offline 454Man
  • Why Race?
Re: Hesitation/bog Problems on my 86
« Reply #30 on: October 17, 2012, 07:57:51 am »
Found mine on an 84 burban with a 350, but 80s burbans seem to be where they can be found with ease.
Offline rockable
  • Truckin', like the do-dah man.
« Reply #31 on: October 17, 2012, 10:37:48 am »
Well, then.  Does my stock ESC controlled 86 305 distributor have that plate?  I haven't looked and don't remember if they even have centrifugal advance.
'86 SWB Silverado
Offline 454Man
  • Why Race?
« Reply #32 on: October 17, 2012, 11:38:49 am »
Yes. If the distributor you find with the plates is in good condition. You can just swap the whole thing mine were in an esc distributor. They look just like the ones that come in the after market kits, but they are the right weight and have the correct curvature needed
The #s are stamped in the top of the center plate and weights. All you have to do is look under the rotor to find them
« Last Edit: October 17, 2012, 02:57:51 pm by 454Man »
Offline rockable
« Reply #33 on: October 17, 2012, 12:10:08 pm »
Cool.  I'll check it out.  I've still got my ESC distributor.  Thanks!
'86 SWB Silverado
Offline 454Man
  • Why Race?
« Reply #34 on: October 17, 2012, 03:02:46 pm »
Yep no problem. All you will have to do is add a couple medium springs from an aftermarket kit and limit the vac advance to 8° and your good to go. Oh and of course set your initial to 10 or 12°. I'm still using my esc dist, just bypassed the controller.
Offline rockable
« Reply #35 on: October 31, 2012, 07:37:45 pm »
My RSC distributor had 444/60 combo in it.  :(
'86 SWB Silverado
Offline 454Man
  • Why Race?
« Reply #36 on: October 31, 2012, 09:14:19 pm »
Awe its ok. :-)  I would say test them out with msd timing tape on the balancer and a timing gun when you get your new engine. Just to see how much mechanical timing they provide. Any how. Keep an eye out for the ones we spoke about. Its a direct swap
