Author Topic: Oil pressure?  (Read 21055 times)
Offline hondarider188
Re: Oil pressure?
« Reply #15 on: December 18, 2012, 07:26:56 pm »
Yeah thats why I took it into the shop was to test my oil pressure to make sure it was just something in the gauge. And not just having a bad engine.
1983 K10 silverado
Re: Oil pressure?
« Reply #16 on: December 18, 2012, 09:19:32 pm »
Restating my earlier post...
Since you've verified that engine oil pressure is good, perhaps your auto shop has a universal "electrical" tester that you can use to actually "test" the dash gauge and sending unit, to help you determine whether the low pressure reading on the dash gauge is a faulty sending unit, a faulty gauge, or wiring/connection problem.  Look at the image for an example...
Offline gildardo01
Re: Oil pressure?
« Reply #17 on: December 19, 2012, 08:16:23 am »
sorry to jump on the thread, but isnīt 25ft lb a little low.... my truck is about 50ft lb on idle...
Re: Oil pressure?
« Reply #18 on: December 19, 2012, 10:56:18 am »
25 PSI at idle is not unusual for a stock engine.
http://forum.73-87chevytrucks.com/smforum/index.php/topic,22586.msg187645.html#msg187645
The "low" idle pressure I experienced in the above thread was due to anti-cavitation grooves machined into the pump cover.
Re: Oil pressure?
« Reply #19 on: December 19, 2012, 05:07:58 pm »
sorry bd I thought you were talking about a universal gauge to test the oil pressure itself. I have already replaced the sending unit so I think its safe to say its in the wireing to the gauge or the gauge itself. And I will try to ask the shop tomorrow if they have one.
1983 K10 silverado
