Author Topic: brake issue... could it be the proportioning valve??  (Read 14201 times)
Offline pholliday1
  • 1990 V3500 Crew Cab
Re: brake issue... could it be the proportioning valve??
« Reply #15 on: January 18, 2013, 09:57:34 am »
The master cylinder is based on certain close tolerances. In a rush to "refurbish" these master cylinders sometimes close enough appears to the motto of some of these companies. My last problem with this issue resulted in a "new" master having tolerances .008 out of spec. which is a football fied of difference.
Offline howlinwolf
« Reply #16 on: January 18, 2013, 10:37:48 am »
meh cant argue with that logic.
78 Chevy Custom Deluxe flatbed, PROPANE POWERED
Offline gildardo01
« Reply #17 on: January 18, 2013, 11:08:47 am »
that makes perfect sense, maybe the bore tolerance is out of range and that's why it won´t build pressure for the rear breaks..
