Author Topic: Transmission problem  (Read 10738 times)
Offline 81_Chevy
Re: Transmission problem
« Reply #15 on: February 28, 2013, 08:01:32 pm »
yep, there was tranny fluid in the vacuum line.
and yeah vile i understand now, but it only did it that one time so im not worried about it that much since the trans was rebuilt not to long ago. and im thinking the little vacuum to the trans may have caused the slipping?
so how would i go about changing the modulator on my transmission? how much would it cost?
thanks -Nic
Offline pholliday1
  • 1990 V3500 Crew Cab
« Reply #16 on: March 01, 2013, 07:22:23 am »
Should just have one little bolt and retainer u clip holding it in. Just remove clip and PULL straight out the new one " should" have new o ring with it. Can't remember what they cost? I don't think it was to expensive though.
Offline 81_Chevy
« Reply #17 on: March 01, 2013, 09:20:56 am »
alright thanks for the help pholliday!   :D
will there be any trans fluid that comes out with it? dont want to make a mess of my dads garage  ;D
Offline pholliday1
« Reply #18 on: March 01, 2013, 10:45:20 am »
Yes, trying to remember how much.... I'm thinking not that much
Offline Engineer
« Reply #19 on: March 01, 2013, 06:00:42 pm »
$20 + or -
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Offline 81_Chevy
« Reply #20 on: March 02, 2013, 02:05:01 pm »
ok so i went out last night to O'Reillys and got one, was like 13bucks, i put it in this morning and i guess it kinda worked. my trans doesnt shift hard now, but it still has the high rpm issue. still a little confused  ??? do i need to adjust the regulator? cuz i know its regulates when the trans shifts.
-Nic
Offline pholliday1
« Reply #21 on: March 02, 2013, 03:22:30 pm »
Yes ,there is an adjustment for the regulator  ,umm thinking you may want to start a new thread on that if someone doesn't respond ,unfortunately I don't know the proper sequence to adjust it is sorry.
