Author Topic: Factory tach in cluster not working  (Read 13835 times)
Re: Factory tach in cluster not working
« Reply #15 on: April 02, 2013, 09:34:32 pm »
B+ is battery positive.
Offline 86silver
« Reply #16 on: April 04, 2013, 08:49:59 pm »
I did as instructed.  Thank You for the tip!  Electrical scares the crap out of me.  Anyway I'm good.  Ground tested fine.  So that means all three wires are light tested and are fine at the tach.  Lets hope the new tach is the winner!
Offline 86silver
SOLVED: Factory tach in cluster not working
« Reply #17 on: April 07, 2013, 08:30:46 pm »
Installed new tach after a final verification that the wiring was good.  Didn't work.  I made up a few words you haven't even heard yet!  Started playing with the two tachs, comparing new circuit boards to old tach (found a dark did colored spot on old...it was fried).
Long story short, the circuit board can only go on one way.  Then you put the little washer over each of the 4 prongs, followed by the little lock washer, then the nut.  Next put on the plastic backing that screws into the cluster housing by 3 screws...then plug in wiring harness to the three prongs sticking through the backing.  Screw plastic backing into housing, then screw in the tach itself.
My mistake?  I put the nuts on the outside of the plastic backing to hold the tach to it...that was a bad idea apparently. The only thing holding that backing to the tach is the harness plug!  Who knew!?!   :)
