Author Topic: Timing / Idle Mixture / Vacuum question  (Read 83513 times)
Offline 74 C-10 Shorty
Re: Timing / Idle Mixture / Vacuum question
« Reply #75 on: June 14, 2013, 10:52:37 am »
At full throttle cable should be all the way out.
Offline bswilson80
« Reply #76 on: June 20, 2013, 07:34:03 pm »
OK, so I replaced the vac advance with a non-adjustable one and I get 36 degrees at idle. The detent cable is maxed out at WOT and the vacuum modulator is getting full manifold vacuum, but when I adjust it (got up to 4 turns counter-clockwise at half turn intervals) the gear shifts don't seem any shorter or softer, so I'm guessing that this went bad during all of the turning of the vacuum advance and whatnot. The truck shifted great before all of this, so hopefully I just blew the diaphragm, I get some white smoke upon cold-start, but I didnt see any ATF in the vac mod line.
Does timing advance affect gear shifting at all? ie the more advance the later the shift? This is the only other thing that I can think is messing up my shifts, and now the clutch is really starting to smell, even after just one short run, so I need to figure this out before I have a huge problem on my hands.
« Last Edit: June 20, 2013, 07:39:31 pm by bswilson80 »
Offline 454Man
  • Why Race?
« Reply #77 on: June 20, 2013, 10:05:33 pm »
36 degrees at idle is way to much. From your vac can all you need is 8-10 degrees this is my setup tried and true from Dave ray aka the ignition man. 375/ 41 center plates and weights from the distributor in an 84 suburban. They provide 21 degrees of mechanical plus 12 initial then 8 of vac. That is all you need. Nothing more or less.
« Last Edit: June 20, 2013, 11:05:02 pm by 454Man »
Offline rich weyand
« Reply #78 on: June 20, 2013, 11:46:02 pm »
You want 36* of advance at 3000 rpm with the vacuum advance disconnected.  For stock distributors, this should 16* at idle with the vacuum advance disconnected.
« Reply #79 on: June 21, 2013, 12:41:50 am »
rich why you have to be so confusing lol i was confused about all this stuff from the get go. but why not just say 16° at idle with the Vacuum advance disconnected
Offline rich weyand
« Reply #80 on: June 21, 2013, 02:25:13 am »
Because it depends on the distributor advance setup.  What you want is 36* when the advance comes in.  The idle setting depends on the distributor.  Stock distributor, sure, then you want 16* at idle.  But if you have, say, 24* advance in the distributor, then you only want 12* at idle.  You only need to check it at rpm once to see what kind of distributor you have, then you can just set the timing at idle once you know what the subtraction is.
« Reply #81 on: June 21, 2013, 03:02:09 am »
so there is no way to check what type of distributor you have unless you "zero" it out, then run to 3k then see what your advance timing is at then minus that from your "zero"
Offline 454Man
  • Why Race?
« Reply #82 on: June 21, 2013, 07:45:03 am »
That's the best way because who knows what's been changed over the years:-)  better than taking a wild guess and detonating a good engine... Or just look up ignition man and follow his past threads...
Offline 454Man
  • Why Race?
« Reply #83 on: June 21, 2013, 08:14:56 am »
Find the lightest advance springs and put them in (only to find out how much advance you have) then take them out. You should only have to rev up to 2k max probably Less
« Last Edit: June 21, 2013, 09:07:17 am by 454Man »
Offline bswilson80
« Reply #84 on: June 21, 2013, 11:00:05 am »
What size springs do you run on those weights, and is there a vac I can buy that only gives 8? Or do I have to modify one?
Offline bswilson80
« Reply #85 on: June 21, 2013, 11:03:32 am »
My apologies, I still have my good initial timing 12 at idle and 36 all in before 3000rpm. I just can't find a vac advance that gives me less than a ton of advance. Any advice on finding one would be much appreciated.
My bigger concern now is the hard & late shifts, is it just a coincidence that these started now, or is there a connection between advance and shift times?
« Reply #86 on: June 21, 2013, 11:48:17 am »
Here's a chart with numbers for vacuum advance canisters, maybe this will help..
http://www.lbfun.com/warehouse/tech_info/timing%20&%20vacuum%20advance/Vaacuum_Advance_Specs.pdf
Offline bswilson80
« Reply #87 on: June 21, 2013, 12:18:38 pm »
Offline 454Man
  • Why Race?
Re: Re: Timing / Idle Mixture / Vacuum question
« Reply #88 on: June 21, 2013, 02:07:59 pm »
I run the medium springs in the moroso kit. I bought the accel vac can because it pulls down to 5hg.
Offline 454Man
  • Why Race?
« Reply #89 on: June 21, 2013, 02:17:00 pm »
