Performance
Lunati cam and Pro Comp head discussion
4
5
6
Topic: Lunati cam and Pro Comp head discussion (Read 63965 times)
dsgb610
Re: Lunati cam and Pro Comp head discussion
Reply #60 on:
September 18, 2013, 01:02:46 pm »
Apologies, I also have center bolt valve covers and a Vortec intake. Currently I have factory GM vortec valve covers bu t i do have the proform ones new in the box. I had read that the centerbolt was the correct primary valve cover for these heads.
nlauffer
Reply #61 on:
September 18, 2013, 01:35:58 pm »
This is the valve cover I was thinking about. Also, the timing chain cover, and air cleaner to match.
454Man
Why Race?
Reply #62 on:
September 18, 2013, 02:09:09 pm »
Nice!
nlauffer
Reply #63 on:
September 19, 2013, 02:36:05 pm »
I just placed my order for Comp's K12-238-2
Sent from my iPhone using Tapatalk -
now Free
nlauffer
Reply #64 on:
September 19, 2013, 04:16:29 pm »
I walked across the street to the Napa to get head gaskets and oil pan set, but they did not have the ones I thought I wanted.
I was thinking about the 1003 or 1010 FelPro head gasket. What does everyone else think.
I also want the one piece oil pan gasket. Which one is it?
nlauffer
Reply #65 on:
September 19, 2013, 04:37:36 pm »
Fel Pro - OS34510T This is the one. anyone have issues with the dual dipstick hole on these gaskets?
nlauffer
Reply #66 on:
October 06, 2013, 09:17:03 pm »
Haven't posted in a while so I better update some.
I received my Comp Cam K kit. I switched out the springs, retainers, and locks on my heads. It already had new seals. I got my oil pump on. I picked up a new oil pan and timing cover and oil pan gasket set. I just need to get the pump pickup attached. I hope to install cam and timing set in a couple days. I am still looking for a dual plane intake close by but I'll probably end up ordering one.
nlauffer
Reply #67 on:
October 08, 2013, 04:50:24 pm »
Cam is in and timing set is on. Although not bolted down as I couldn't find my cam gear bolts. I got some new ones just a bit ago.
I have "cast iron" engine paint, "aluminum" engine paint, and "black" engine paint. I can't decide I keep changing my mind on the color. The only thing I am certain of is the black valve covers and air cleaner from Procomp. Let me know your ideas. I'm leaning towards black.
nlauffer
Reply #68 on:
October 09, 2013, 11:31:00 pm »
I've got an opportunity to buy a stock GM aluminum intake manifold. Does anyone know if these are worth it?
rich weyand
Reply #69 on:
October 10, 2013, 12:31:45 am »
Is it a dual plane manifold? There will be a divider fore and after through the center of the carb/TBI mounting location if it is. The dual-plane GM ones are OK.
Been thinking about engine color. With the black valve covers, I would go with something contrasting, like Chevy orange, body color, or aluminum.
nlauffer
Reply #70 on:
October 10, 2013, 01:28:34 am »
I was thinking About aluminum color and started to paint it but it just didn't look right. Maybe cause I didn't do the whole thing. I like the contrasting colors most. The black was kind of giving up on deciding. I like the orange but I want something a little different.
rich weyand
Reply #71 on:
October 10, 2013, 02:06:14 am »
You could do a hammertone finish. My bro does it on machine tools and it is awesome looking. Tough as nails, too.
I'll ask him what brand he uses.
One important note: the finish has a little bit of a grain or direction to it from brush strokes, so you have to brush it all in one direction. He gets around that by stippling it with an acid brush.
nlauffer
Reply #72 on:
October 10, 2013, 03:17:51 pm »
I thought I saw a small block build on PowerBlock's Horsepower, where they used aluminum paint on the bulk of the engine. I like the way it looked, but I can't find the episode and can't remember for sure what it ended up looking like.
rich weyand
Reply #73 on:
October 10, 2013, 04:19:03 pm »
I don't see it either. Normally for manifolds and water pumps and stuff they use "Dupli-Color Paint, Engine Enamel with Ceramic Resin, Gloss, Aluminum, 12 oz., Aerosol."
Here's a picture of an aluminum painted block from a forum. It's in a Vette:
Here's what a Hammerite finish looks like. Hammerite is the brand my bro uses. You must either spray it on or stipple it on with a cut-short brush, or it will show brush marks. This is "graphite" color:
Last Edit: October 10, 2013, 04:21:25 pm by rich weyand
nlauffer
Reply #74 on:
October 16, 2013, 09:09:28 pm »
Quick update and a couple questions.
I have the heads torqued down and oil pan and timing cover on.
I was looking over my block and was wondering why there are so many threaded holes in the block. Does anyone have a diagram or something of what all the holes were used for? I know which ones are for motor mounts and fuel pump and front accessories, also the ones scored oil pressure. But, there is another one near the oil filter location and a couple on each side of block about mid way.
What do I need to look for in regards to whether or not my distributor could use rebuilding?
4
5
6
Performance
