Author Topic: Can't do 55!  (Read 10190 times)
Offline 77 cc lb
Re: Can't do 55!
« Reply #15 on: August 08, 2013, 03:57:01 am »
Thank you for the info guys! I will check cap and wires and probably dump the cat today. Hopefully it will be one of these things.  Thanks again!
87 Chevy crewcab shortbed soon to have a 454/400
Re: Can't do 55!
« Reply #16 on: August 08, 2013, 04:11:59 am »
timing and firing order also since you will be in there
Re: Can't do 55!
« Reply #17 on: August 11, 2013, 02:08:22 pm »
     Before eliminating things that are not the problem do what BD Suggested.
Check the exhaust backpressure for possible restrictions.  Should measure under 1.5 PSI @ 3,000 RPM.
