Author Topic: 454 TBI truck backfires on cold start for about 30 seconds  (Read 45184 times)
Offline rich weyand
Re: 454 TBI truck backfires on cold start for about 30 seconds
« Reply #30 on: October 17, 2013, 11:57:56 pm »
Check the MAP sensor and the connections to it.  Without the O2 sensor on-line, that will determine your mixture.
« Reply #31 on: October 18, 2013, 06:01:58 am »
i want to get on this post also. soooo, do you have your heat riser pipe still installed?
did you check timing?
« Last Edit: October 18, 2013, 06:23:15 am by Irish_Alley »
Offline Chevy3+3
« Reply #32 on: October 18, 2013, 07:06:21 am »
Heat riser pipe is still installed. Everything is bone stock under the hood. I need to fix exhaust leaks first and go from there I guess. I just set the initial timing to around 5 degrees BTDC.
The dizzy cap is an MSD and the plug wires are 8.5mm and appear to be new and high quality. I think the previous owner put them on trying to resolve the same backfiring problem. I just bought this truck and this morning backfiring is the only thing left to fix.
I greatpy appreciate all the help and wealth of knowledge some of you bring and share here. I am a very mechanical guy but sensors and electronics are a little out of my element.
« Reply #33 on: October 18, 2013, 11:29:07 pm »
you "just" set the timing? when? not doubting your skills but you did connect the tan/black wire before setting timing at ot?
i know you siad you replaced the cts but if you have a used one in another truck i would swap them out or just replace yous again. heck i just bought a ckps from a dealer for $100 when i could buy autozones for $40. sometimes they are bad right out of the box
could try to test it also
212°f 177 ohms
194°f 241
176°f 332
158°f 467
140°f 667
122°f 973
113°f 1188
104°f 1459
  95°f 1802
  86°f 2238
  77°f 2796
  68°f 3520
  59°f 4450
  50°f 5670
  41°f 7280
  32°f 9420
  23°f 12300
  14°f 16180
    5°f 21450
Offline Chevy3+3
« Reply #34 on: October 19, 2013, 09:59:42 pm »
Okay well a little update. I got the passenger side exhaust manifold replaced and the gasket was blown. Both flange gaskets were leaking also. The spark plugs were crap. Someone installed Bosch platinums and that was a bad choice. I replace the plugs with AC Delcos and replaced cap, rotor and wires also. After changing everything listed ablve I still have an exhaust leak. I hoped the drivers side manifold gasket wasn't blown but it apparently is.
Since I have a fuel mixfure issue and run a little rich at all timez I bet the drivers side gasket being blown is allowing aire to be drawn in before the O2 sensor causing a lean reading and therfore causing the TBI to dump excessige fuel.
As for the timing. I got thr truck to operating temp and then unplugged the brown wire with black stripe. After doing so the timing light showed the timing to be set at 0 degrees. A big block is to be set at 4 degrees BTDC. I set it on about 5 degrees BTDC. I then shut the truck off. Unhooked battery cable and plugged bypass wire back together. Then hooked up the battery and proceeded to start the truck. Let me say what a difference it made having the timing set properly. Itruns so much better now. The motor feels more responsive and smoother.
Offline 454Man
  • Why Race?
« Reply #35 on: October 19, 2013, 11:30:41 pm »
Glad to hear all is going well. After that next gasket you'll be even more happy...
Offline Chevy3+3
« Reply #36 on: October 21, 2013, 02:09:22 pm »
Well I just finished replacing my drivers side exhaust manifold gasket. There wasn't a lot left of it. The truck is runningso much better. Who would have thought exhaust leaks could cause so many issues.
Now I need a cooler morning and see if she backfires on a cold start up.
Offline 454Man
  • Why Race?
« Reply #37 on: October 21, 2013, 02:40:01 pm »
I believe the term its reversion. Cold air being drawn back into the cylinder causes it. I'm searching for some good header gaskets now. Mine keep telling me to shhh lol
« Reply #38 on: October 21, 2013, 05:13:08 pm »
...Now I need a cooler morning and see if she backfires on a cold start up.
They'll be upon us soon enough....
Offline Chevy3+3
« Reply #39 on: October 21, 2013, 10:30:34 pm »
I bought some years ago that were Mr. Gasket. They were around $18 for a set i think. They were black with some blue print on them. I used those with some good header bolts and never had another problem for many miles and several years.
Offline 454Man
  • Why Race?
« Reply #40 on: October 22, 2013, 11:04:23 am »
I'm gong to look into those thanks. Glad to hear its running better
Offline Chevy3+3
« Reply #41 on: October 23, 2013, 10:26:15 am »
Well it was officially cold enough early this morning I got to try a cold start up. I was pretty nervous and hoped I had solved the backfiring issue. I cranked the key over and she fired up and ran smooth and no backfiring. No I can concentrate on other things. My 2.5" lift will be here today but probably won't have time to intall it until next week sometime. I also think I am gonna throw a Flowmaster Super 44 muffler on it. I don't drive it everyday and I am still young enough I don't mind hearing a little noise out the back.
Offline 454Man
  • Why Race?
« Reply #42 on: October 23, 2013, 10:56:11 am »
That's what I'm takin bout :-)
« Reply #43 on: October 23, 2013, 11:06:57 am »
>Chevy3+3
     Rave congratulations on your success!!!
>454Man
     You may want to look into the Felpro 1404 for your exhaust, as well.
Offline 454Man
  • Why Race?
« Reply #44 on: October 23, 2013, 11:48:54 am »
Thanks bd.
