Author Topic: 03 and up crown vic crossmember swap  (Read 44707 times)
Re: 03 and up crown vic crossmember swap
« Reply #15 on: November 16, 2013, 05:56:22 pm »
Nice, it is going to be interesting how you connect the steering column to the rack and pinion
Offline dale
« Reply #16 on: November 16, 2013, 10:29:55 pm »
thanks!  Crown Vic And a mustang steering shaft with a pillar bearing.... o, and a tig machine
Offline HAULIN IT
« Reply #17 on: November 19, 2013, 01:59:04 am »
I'll keep watching at this time
Offline nlauffer
« Reply #18 on: November 19, 2013, 08:52:00 am »
Motor mounts?  What are you thinking on those.
Offline dale
« Reply #19 on: November 19, 2013, 07:25:25 pm »
Found out frame was bent.. just got metal in to build a full tube chassie!! Ihave a pair of ls mounts... fab some brackets on the frame.
