Author Topic: gas to diesel swap  (Read 34917 times)
Offline Stewart G Griffin
Re: gas to diesel swap
« Reply #15 on: December 28, 2013, 07:53:29 pm »
i thought the 6.2 and 6.5 were the same engine?   Like the 305 and 350 are the same engine.
« Reply #16 on: December 28, 2013, 07:58:00 pm »
Here is a 6.5 in a corvette:
http://ecomodder.com/forum/showthread.php/corvette-v8-diesel-conversion-40-mpg-us-avg-1128.html
So it seems like it would pretty straightforward provided you knew what exactly was needed---the ancillary parts and pieces.
Offline hatzie
« Reply #17 on: December 28, 2013, 08:20:26 pm »
They are externally.
The 6.5 after 1992 got a factory turbo system and serpentine accessory belt somewhere near that time.
The factory turbo is engineered to fit the T400 chassis.  It can probably be modified to fit the CK RV squares but the turbo needs to be mounted closer to the the radiator.
From orbit via Android.
« Reply #18 on: December 29, 2013, 09:25:51 am »
The 6.2L and 6.5L are the same motor but the turbo was designed for the 88-98 chassis.  A non-turbo will easily swap.
captkaoscustoms.com
squarebody.biz
Offline fitz
« Reply #19 on: January 20, 2014, 07:28:58 pm »
Around here cummins 6 bt's sell for around $2000. You can buy 6.2 J code motors from Military CUCV'S  for $300-$500 all day long on craigslist.
« Last Edit: January 20, 2014, 07:37:58 pm by fitz »
