Author Topic: Fuel Guage broken ?  (Read 36493 times)
Offline darmentle
Re: Fuel Guage broken ?
« Reply #31 on: December 14, 2013, 03:19:39 pm »
So am about to say oh well and get an aftermarket cheap fuel gauge and see if that works.
« Last Edit: December 14, 2013, 04:16:00 pm by bd »
Offline rich weyand
« Reply #32 on: December 14, 2013, 06:35:23 pm »
Measure the ohms between the ground terminal on the gauge and the chassis, even better between the ground terminal of the gauge and the ground of the battery.  I'm pretty sure the problem is on the ground side of the gauge.
Offline darmentle
« Reply #33 on: December 14, 2013, 06:48:45 pm »
do you know where the ground wire from the fuel gauge goes like where its bolted to does each gauge have there own ground .
Offline rich weyand
« Reply #34 on: December 14, 2013, 07:13:37 pm »
Depends a bit on the year.  What year and model of truck is it?
Offline darmentle
« Reply #35 on: December 14, 2013, 07:47:55 pm »
73 k20 4x4
Offline rich weyand
« Reply #36 on: December 14, 2013, 10:06:27 pm »
Here's the pointer to all the manuals.
http://forum.73-87chevytrucks.com/smforum/index.php?topic=25639.msg213706#msg213706
From the pointers in that message, here's the wiring manual for your truck.
http://www.73-87chevytrucks.com/techinfo/7387CKMans//Wiring/X_7305_1973_GMC_Truck_Wiring_Manual_CK_10_30_Pgs_Only.pdf
The ground from the instrument cluster is the wire at the lower left of the connector (also lower left as mounted in the truck) labeled 20B-150B.  The "B" in "20B" stands for black, so that should be a black wire (BRN is brown, LBL is light blue, DBL is dark blue).  As shown, it immediately goes to a 4-wire splice behind the dash.  One of those wires, labeled 20B-150A, goes to a sheet metal ground.  Find the splice, check it.  Find the sheet metal ground, check it.
Offline darmentle
« Reply #37 on: December 15, 2013, 03:46:56 pm »
I got it working i had to install a aftermarket gauge thanks for your guys help.
Offline rich weyand
« Reply #38 on: December 15, 2013, 04:49:27 pm »
How weird.  Broken ground wire inside the gauge maybe?  From tests it seemed like the gauge was good.
Anyway, you got it, so that's good.  Thanks for letting us know.
Offline darmentle
« Reply #39 on: December 15, 2013, 07:14:19 pm »
Well there was two issue going on . The ground was fine the first problem was that the wire for the sending unit wasn't sending a signal at the gauge cluster. I tested the the  connection at the cluster and i was getting no ohms there. So i followed my sending wire to the out side junction at the fire wall and tested it 84 ohms i had little less then a full tank so it was correct. So i ran a jumper wire from the wire at the junction to my OEM fuel gauge and it was still having a problem. So i just hooked up the aftermarket gauge.
Offline rich weyand
« Reply #40 on: December 15, 2013, 08:33:49 pm »
By aftermarket gauge, was it a direct replacement gauge for the OEM?
Offline Boone83K10
« Reply #41 on: December 15, 2013, 08:44:20 pm »
that fuel selector is correct for your year. Well you narrowed the problem down to inside the dash. how did you wire up the aftermarket? you obviously had to go outside the cab or else is should not have worked either if you spliced into it in the dash.
well if your jumper wire didn't work then it is the gauge.
« Last Edit: December 15, 2013, 09:14:56 pm by bd »
1966 Mercury Comet - Built 429 (First Car/Show Car)
1983 Chevrolet K10 - Built 350 (Winter Toy)
1992 Chevrolet Lumina Euro (Sold @ 265,000 miles)
2003 Ford Escape 4x4 - Mac Perf. Intake/Exhaust (Wifes' DD)
2007 Mercury Milan - Steeda Tuned (Summer Toy)
Offline darmentle
« Reply #42 on: December 16, 2013, 08:07:30 am »
i just bought a cheap aftermarket gauge little 2" one from orielys for now. i was getting signal on the inside the cab at the fire wall so i ran the wire there. for now i am gonna run like that until i can find a working OEM in gauge  then i will pull out the whole gauge cluster and fix it right.
Offline rich weyand
« Reply #43 on: December 16, 2013, 10:47:54 am »
Offline darmentle
« Reply #44 on: December 16, 2013, 10:56:58 am »
Sweet thanks again 50 Bucks  for a fuel gauge is good deal and knowing that its working is a even better
