Author Topic: cheapest way of lowering a truck  (Read 14944 times)
Offline 77c15
  • combustion=suck, squeeze, bang, blow
    • My cardomain site...
leveling the rear, cheaply
« Reply #15 on: February 18, 2005, 10:24:00 pm »
Summit Racing Equipment offers "Ground Force" (under Summit name, of course) shackles for fairly cheap, and   Truck just started carrying individual lowering components. Hope this helps. Check out my page (page 2) for my shackle install.
-Mike
www.cardomain.com/memberpage/788720
Offline 87swb
« Reply #16 on: February 19, 2005, 09:27:00 pm »
well i got another question, what do ya'll mean by axle wrap? is that something bad?i just want my truck to sit a little lower in the back, maybe an inch or a little over.i don't want it to sit lower in the back than in the front.isn't stock height 2 inches higher then the front?
Offline roundedline
Re: cheapest way of lowering a truck
« Reply #17 on: February 19, 2005, 10:55:00 pm »
Axle wrap is where the axle twists the springs up in the front.  I haven't had a problem with this with a normal flip kit.  If you use blocks in addition to this is when it can happen.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline 87swb
air shocks
« Reply #18 on: March 01, 2005, 06:28:00 pm »
well if i use air shocks can't i adjust the way it sits?
Offline roundedline
Re: air shocks
« Reply #19 on: March 02, 2005, 02:07:00 pm »
Offline 87swb
air shocks
« Reply #20 on: March 13, 2005, 06:58:00 pm »
i take it you've had bad luck with these. is there a downside to them?
Offline shadecrack
Re: air shocks
« Reply #21 on: March 19, 2005, 07:36:00 pm »
I had a set on my 74 nova, it worked great!, I could tune the shocks to put just enough pressure to make the tires hook up:D  the only downside was when I was driving home on night in the rain (isn't it weird how things break down late at night out in the boondocks in sucky weather?)  and I blew the back right shock out... not fun.. driving along , hit a bump and suddenly the back right of the car feels like it is dragging,>:  not fun to drive home , and not fun trying to get the jack under the car.. look a stock 74 nova hatchback and you will understand..
other then that , I loved the cheap tune-ability of the shocks .
eugene
