Author Topic: lowering for free  (Read 29393 times)
Offline longnlow81
Re: lowering for free
« Reply #15 on: June 20, 2007, 02:35:44 pm »
what i meant was my rear sits high already just wondering if i do the flip will there be a need to cut my coils or do you think the flip could level it out?
81 c10 longbed
« Reply #16 on: June 20, 2007, 03:15:03 pm »
If you do a flip kit the rear is going to be significantly lower than the front.  If you want it level without cutting the coils, you can do a shackle kit.  To make one level it needs to go down about 2" in the rear.
Offline longnlow81
« Reply #17 on: June 20, 2007, 03:24:22 pm »
yea i acually thought for once and vroke out the tape measure, and the back would be lower, now my only problem is getting the bed off, been out there for a while with the impact and wont break the bolts loose, so im tking a break and thinking about it this truck was acually suppose to be what i want it to be
81 c10 longbed
« Reply #18 on: June 20, 2007, 03:59:09 pm »
Get some PB Blaster and soak the bolts/nuts down.  The last think you want to do is round off the hole in the bed.
Are you removing the bed to do the flip?
Offline longnlow81
« Reply #19 on: June 20, 2007, 04:13:33 pm »
yea ive already use the rest of my pb blaster on them about 3 or 4 onths ago i cut the back 4 out and now im just thinking about waiting to do this
now im just looking at buying 3 inch drop coils and djm 5 inch flip kit from summit, cheaper there, and i just starting with a 3/5 would be better for now
81 c10 Longbed
« Last Edit: June 20, 2007, 08:34:14 pm by longnlow81 »
Offline Lon
« Reply #20 on: June 25, 2007, 10:54:29 pm »
On the rear you dont have to remove the bed to do a flip kit. It is harder to get to things but it is possible, unless you really want to remove thebed for another reason.
1984 GMC Sierra. Air Bagged but mostly stock.
