Author Topic: Lets see your 73-87 LS swap!  (Read 46771 times)
Offline LSXCHEVY
Re: Lets see your 73-87 LS swap!
« Reply #15 on: September 16, 2015, 11:01:47 am »
1984 C10 'Custom Deluxe'
all iron lq4, eddy 2215 cam,eddy dual plane, holley 670, ls6 valve springs, cam and main/rod bearings, rocker arm tunnion upgrade, basically rebuilt stock heads, new valves and such, melling high volume oil pump, steam vent ported to drilled hole in waterpump, got new pistons after first start of this motor that ran for few miles spun a rod bearing or 2...currently running..haven't taken to dyno but im at (MSD 6010) 30* all in timing around 2000rpm...idle at 22*.. has 2000rpm stall converter with 700r4 built trans and 3.73 gear, front end rebuilt from the dust cap to the bushings..need stabilizer bar...new clambshell mounts with dirty dingo slider mounts..new alt, PS, WP...2/4 drop, well working on the other 2" n the back..need to install hangers (being lazy)...interior was done about 3 years ago..probably could use some reconditioning...trying to think of more..had this truck for about 4 years.. I run 10w30 VR1... a lot of time and effort.as you guys would know...pretty sure there are a lot of things I cant think of right now but its coming together..  future plans include Caltracs, TrueTrac, 20x8/10 wheels, not sure on paint color (was already painted burnt orange when I bought it), maybe change cam to more aggressive..
not sure if this picture thing will work but here it goes...
http://s484.photobucket.com/user/FIREDECKPERFORMANCE/library/
« Last Edit: September 16, 2015, 03:16:20 pm by Irish_Alley »
Offline frotosride
    • WFO CONCEPTS
« Reply #16 on: September 16, 2015, 07:17:21 pm »
LSX, look good... What gauges do you have in the dash? Also what header/manifold do you have?
Offline frotosride
    • WFO CONCEPTS
« Reply #17 on: September 16, 2015, 07:20:08 pm »
Manchu, made any progress on the build. I'm especially curious about headers or manifold selection as well as the 4L80 to N208 adapter... Did you ever settle on one? I plan on having the same drive train when I get my hands on a 4l80 to put behind this 6.0...
 Currently, 6.0L LQ4 from 03 Denali
Dirty Ding mount
Pots Per. Dbc throttle body for the 700r4
Plans: 4l80E, cam, headers and in time twin hair driers!! Can't wait.
« Last Edit: September 16, 2015, 07:26:23 pm by frotosride »
Offline LSXCHEVY
« Reply #18 on: September 17, 2015, 09:29:21 am »
thanks Froto.. still so much to do and clean up...
six pc gauge set from ebay..led lighting..came with the senders..bought these about 3 years ago..
Schoenfeld Headers  1302LS1  fit perfect with no mod, really close on passenger side frame rail but not touching.. painted them with ceramic header paint about 6 mos ago..
Offline frotosride
    • WFO CONCEPTS
« Reply #19 on: September 17, 2015, 03:02:48 pm »
At first they looked like shorties but now more like mid possibly long tube. Can you post a pic of how far the collector comes down the frame and possibly a measurement from the wheel well?
Offline frotosride
    • WFO CONCEPTS
« Reply #20 on: September 17, 2015, 03:13:35 pm »
Just looked them up and a review posted an '87 K5 swap with no issues so I'd imagine my 4x4 set up would be close if not identical...?
Offline LSXCHEVY
« Reply #21 on: September 17, 2015, 04:13:25 pm »
I will take more pics when I get home... im not sure where your tcase comes into play on the front.. only issue I had was the original bung hole for the AF sensor was in line with gear selector..had to move bung hole back a few inches.. the 1302LS1 are full length long tubes...love the sound at high rpm...
Offline roundhouse
« Reply #22 on: March 28, 2016, 10:25:14 pm »
Offline roundhouse
« Reply #23 on: April 06, 2016, 06:39:42 am »
« Last Edit: March 04, 2019, 02:07:42 pm by roundhouse »
Offline roundhouse
« Reply #24 on: April 06, 2016, 06:58:25 am »
Anyone else have to move the transmission forward ?
We pulled the 350 and the LS hits the firewall about an inch and a half before it hits the bell housing
Offline Displaced_Txn
« Reply #25 on: April 13, 2016, 02:44:43 pm »
the mounts i used put the rear of the ls in the same spot as the sbc, had to move the both the 4l70e and nv4500 forward about 1-2" from where the th400 was at. but easily had enough room to pull and install both trans with no problems with the motor mounted
