Author Topic: hydraulic clutch pedals  (Read 16747 times)
Offline LeftysRodandCustom
Re: hydraulic clutch pedals
« Reply #15 on: May 04, 2014, 07:06:00 pm »
You can also use the master cylinder with a remote reservoir from the 4 gen camaros, I think the 98-02 ones have it. If you have the slave cylinder that goes to the clutch fork most any master cylinder will work with a little fab on the rod. I run a hydraulic throwout bearing in mine with a wilwood master cylinder but thats a whole other ball game.
Offline eventhorizon66
« Reply #16 on: May 11, 2014, 01:20:45 pm »
There might be some demand, considering the increasing popularity of these trucks and of pro touring type machines.
They are definitely getting hard to find, but they are still out there for those willing to call around.  After about 25 or so calls all over the country, I found a set in Washington at a salvage yard called Torgerson Wrecking.  I had it shipped to my door for $105.  I was very pleased.  If I hadn't found that set, I think I would have fabbed something up myself.  But there are those who won't want to or can't.
For anyone looking, don't forget to check all available applications:
85-87 1/2 tons
85-91 Blazers, Jimmys, and Suburbans
85-91 3/4 and 1 tons
'85 C10 SWB 350 700R4 TKO600
