Author Topic: good motor to build?  (Read 33593 times)
Offline bored and stroked
« Reply #15 on: July 03, 2002, 03:52:00 am »
good call. I forgot about the 1pc rear main 383 from GM.
Offline 79SilveradoK30
HT383
« Reply #16 on: July 23, 2002, 09:52:00 pm »
Those HT383s are great motors, from what I hear. I recently read an article in Chevy High Performance where they went and modded an HT383. They swapped in a Comp Cams Xtreme Energy #282 hydraulic roller cam, an Edelbrock RPM Air-Gap Vortec intake, some slight headwork for the pushrod guides and valvesprings, GMPP 1.6:1 rockers, and a Barry Grant 750 cfm Speed Demon carb, and boy they did good. It made about 449 bhp @ 5300 rpm and 486 lb-ft @ 4200 rpm. It also made over 400 lb-ft of torque from at bit above 2000 rpm all the way to 5800 rpm!!
82ChevySWB4X4
  • Guest
Re: HT383
« Reply #17 on: August 31, 2002, 10:13:00 am »
I've been running a 383 stroker motor in my truck for 7 years now.
Anyone who says a stroker won't last doesn't know what they are talking about.
Offline RSBAD454
what motor
« Reply #18 on: September 16, 2002, 01:58:00 pm »
all depends on the use of the truck? 383 in my book is over rated. if you want raw torque get a big block. if you cant afford a big block get GMs ZZ4 crate 350 you can get dang near 375 HP from that setup. many ways to go here.................?
http://
Offline 79350pu
cubic inches
« Reply #19 on: September 27, 2002, 03:46:00 pm »
How many cu's is a 350 bored .60 over?
