Author Topic: 85 K10 4x4 questions  (Read 14409 times)
Online bd
Re: 85 K10 4x4 questions
« Reply #15 on: April 05, 2014, 12:31:40 am »
The timing marks line up every engine revolution, but the engine rotates "twice" for each complete revolution of the distributor.  For the distributor rotor to point toward #1 you needed to rotate the engine one more revolution.
Unless you are timing off of the wrong cylinder, the problem you describe trying to set the timing with your light suggests a spun or wrong balancer.  The method you described from your manual is too crude to determine whether the balancer has slipped and that the timing marks are accurate.  For this purpose, use a piston stop.  See the thread:  Not 100% what's wrong here for an explanation.  You should also check the amount of play in the timing chain - see, Re: 86 C10 Loping for the procedure.  Verifying the timing marks and chain play are not difficult, and both are fundamental to a properly running engine.
On the 'valve rattle,' what does the oil pressure gauge indicate and what oil are you using?
Offline BackCountry
« Reply #16 on: May 05, 2014, 08:12:05 am »
ok, update, I ran seafoam for about a week and did an oilchange to fix the valve rattle.
yesterday I put a new fuel sending unit in the tank to get my fuel gauge working. that gives me my next problem: the needle on the gauge sees to be about 1/4 turn off.
as in: when the tank is full  the needle us just below the E on the gauge. when the tank is empty the needle is down by the word Unleaded at the bottom of the gauge window.
it's like the gauge is moving up and down instead of side to side - like I need to turn the whole gauge clockwise a 1/4 of a turn. is this possible or is there another fix?
BTW: I gave this issue its own thread in "Electrical" directory
« Last Edit: May 05, 2014, 08:32:36 am by BackCountry »
