Author Topic: Wandering loose steering and wheel bearings  (Read 16464 times)
Offline roundhouse
Re: Wandering loose steering and wheel bearings
« Reply #15 on: May 22, 2014, 12:37:28 pm »
A little tip......... When repacking wheel bearings place the bearing and grease inside a zip lock bag and then knead the grease into the bearings with your thumbs. Add more grease to your  bag as needed. No MESS!!!
And if you have one of those vacuum sealer things in the kitchen.  They work great
Put the bearing and grease in the bag.  Vacuum seal it a time or two and it gets the grease in all the spots
Offline sbx22
  • 1974 1/2 ton 350 sbc
« Reply #16 on: May 24, 2014, 06:35:47 pm »
I didn't see this suggestion above but steering slop can also come from the rag joint. there's another name for  it, but I forgot.
