Author Topic: Good deal? Worth the money?  (Read 12543 times)
Offline xschroederx
Re: Good deal? Worth the money?
« Reply #15 on: September 04, 2014, 08:24:23 pm »
I would say no more than 2 to 3 hundred. I paid 200 for mine and it had a spun bearing in the connecting rod to cylinder 1. Block is good, but it required a full rebuild. Luckily I had a spare 350 laying around. Since I bought it, I replaced the clutch, replaced both headlights, put a stereo in it, amp and woofer, tach, cluster glass, cluster lighting, wiper switch, heater blower motor, alignment, tire rotation, swapped the back glass for split window, battery, battery wiring, headache rack, spot lights (mounted and wired) ignition cylinder lock, adjusted idle, flushed the front and rear differential, filled the tcase and flushed the transmission, cleaned the bead surfaces on all 4 rims, installed the cb, bed rail protectors, door seals, lightly detailed interior, wiring trailer brakes, front bumper, and swapped out door locks. I still have to replace the front output shaft seal on the tcase, and measure the yoke for a speedy sleeve. Im down to the almost nothing left except body work which I also have primed, I just need to paint the fenders, hood, cab visor, grille, and grile trim. Then its on to the cab, doors, bed and bumper. It helps that I mechanic for a local dealership. The point is, I still have a mountain of work ahead of me to get this truck running really good and looking really good. This is just so you know the kinds of problems your going to run into that will require eventual attention that will be a more expensive investment than your getting yourself into. If you have the time money and know how to take on a project like that, then more power to ya. But sometimes you get what you pay for. The only reason I took on this project is cause I have a love for restoring old chevy trucks.
« Reply #16 on: September 04, 2014, 08:36:49 pm »
      I can not stand it anymore, is this acceptable in the English language today.
     What is the deal with the all in 1 paragraphs ?  Am I missing something or is this how it is taught these days ?  It makes it hard to read, try rereading what you wrote and see how hard it is to read.
Offline xschroederx
« Reply #17 on: September 05, 2014, 07:27:45 pm »
talking to me?
« Reply #18 on: September 05, 2014, 10:53:44 pm »
he might be, but yours aint nothing compared to some
Offline xschroederx
« Reply #19 on: September 08, 2014, 06:41:20 pm »
Seems a bit rude. Oh well. My post was to inform the original poster the amount of work that will take place when you take on projects of that magnitude. Not sure how that affects a different posters life.....  Im sure we can all make a fair assumption the guy will be knee deep in repairs.
« Reply #20 on: September 09, 2014, 10:36:33 pm »
rude? maybe lol. but heres the thing, lets say you have a post just like above and post a question in the post. i can tell you right now i dont read post like that i skip over them. im not a English teacher or "grammar Nazi" but space it out a little so it all doesn't blend in for us with old eyes lol
