Author Topic: Help with carb  (Read 30906 times)
Offline Chisholmcody
Re: Help with carb
« Reply #15 on: October 22, 2014, 03:22:00 pm »
New issue lol never ends but now I noticed etheir there is no high idle when cold (use to be on for 3min) but now it is not on at all. This started after I turned the choke up to a richer mixture due to it stuttering when I pushed the throttle when cold. Could I have broken or Miss adjusted anything to make the high idle stop working?
Also it does have the automatic choke.
Re: Help with carb
« Reply #16 on: October 22, 2014, 05:02:29 pm »
Never mind found the issue- the high idle cam was loose from the base of the carb causing it not to engage the high idle
Online bd
Re: Help with carb
« Reply #17 on: October 22, 2014, 05:27:57 pm »
The fast idle cam screw is torque prevailing and should not back out by itself.  Put 1 - 2 drops of blue Loctite on the screw threads to lock the screw in place.  But, don't use so much that it oozes out and glues the cam, too.
Re: Help with carb
« Reply #18 on: October 22, 2014, 07:47:50 pm »
Ok thanks for the info
