Author Topic: 79 350 Chevy cuts out on hwy  (Read 12242 times)
Re: 79 350 Chevy cuts out on hwy
« Reply #15 on: August 23, 2014, 05:57:04 pm »
Why you pushing 10k. On my phone but it you search on here for distributor eBay you will find it
« Reply #16 on: August 23, 2014, 05:58:17 pm »
« Reply #17 on: August 23, 2014, 08:05:43 pm »
Pickup coils can fail intermittently.  In fact, it's a rather common scenario.
1,000 RPM huh?
Super 65kv HEI Distributor
« Reply #18 on: August 23, 2014, 09:16:57 pm »
I don't know bd that ones only good for 7k
Offline 79K10Crusher
« Reply #19 on: August 28, 2014, 09:39:23 pm »
Plugs and wires changed lately?  Simple stuff is usually what it is....
Offline wired1141
« Reply #20 on: August 29, 2014, 07:34:12 pm »
Finally had time to fix it, it was the pick up coil. THANKS for all the input it was a lot I needed to learn.
« Reply #21 on: August 29, 2014, 10:58:30 pm »
glad you got her figured out. maybe i need to replace my coil on my 94. wonder if it was a bad connection on the coil?
Offline FearNoMan78k10
  • A project turned into a complete rebuild
« Reply #22 on: August 30, 2014, 12:26:22 am »
Sounds like it is a possibly that's for sure.... Hmmm... Yeah you should look into the coil... Distributor... See if you can come up with something?  I'm feeling inside like your on the right track there Irish ...
78 k10 4x4
Offline 78BIG-TEN
« Reply #23 on: August 30, 2014, 01:22:39 pm »
you must mean 1000 rpm what about spark plugs.they could be glazed
