Author Topic: Fresh rebuild on 700R4 exhibiting Failsafe/limp mode symptoms??  (Read 14274 times)
Offline caunchman
Re: Fresh rebuild on 700R4 exhibiting Failsafe/limp mode symptoms??
« Reply #15 on: September 02, 2014, 12:21:01 pm »
  Yea shifts great...had to shim the starter slightly....weird cause you aren't suppose to have to shim Ford style starters, then again you probably ain't suppose to put a chevy transmission behind a Jeep engine...but while rotating the flex plate would contact the starter gear a .0625  shim brought it out just enough...I can't emphasize how valuable a pressure gauge is for these transmissions.
