Author Topic: Tips for getting front leaf eye bolt unstuck  (Read 14191 times)
Offline jumpkickyergunt
Re: Tips for getting front leaf eye bolt unstuck
« Reply #15 on: September 21, 2014, 03:22:07 am »
Woohoo. Got 3 of 4 done. The rear is tough. It's dang near impossible to get the leaf downward to bolt in without ratcheting straps. I felt completely unsafe the entire time, but it's definitely in there. Sawzall was the main tool used to cut the bolts out. Went through the sleeves again.
I still need help on torque specs if anyone has that information.
« Reply #16 on: September 21, 2014, 05:55:21 am »
are you getting a lift kit? specs should be there. also i know on my 79 mud truck someone cut holes in the inside of the shackles to get to the bolts. plasma cutter helps also if you have one
« Reply #17 on: September 21, 2014, 07:22:33 am »
They just need to be set to German torque spec. GOODNTIGHT Or the three grunt method, Once they are tight give them 3 good tugs while grunting.
« Reply #18 on: September 22, 2014, 08:53:10 am »
       ;D
Offline pholliday1
  • 1990 V3500 Crew Cab
« Reply #19 on: September 22, 2014, 11:25:20 am »
Conflicting information? Well okay let me give you some. First let me restate the obvious, the reason you cant get the bolt out is because its seized to the sleeve. This is one of the main reason our trucks suffer poor ride quality. The suspension become frozen and you lose the first couple inches of articulation. When  I reassemble or install a leaf pack ( I prefer poly bushings over rubber just personal preference) all bushings and bolts get a good coating of never seize on metal parts and poly lube on poly parts to include the rear and front shackles that hinge. When I reinstall the bolts I use a locking nut and tighten just enough to gently snug all the components up. I never over tighten shackle bolts as this restricts articulation. The shackle bolts aren't really subjected to high lateral forces so just snugging up the bolt (with the proper lock nut with threads showing all the way through the nut) still allows the suspension to do it job. If your leaves are rusted in between and are "stuck together" this also leads to very poor ride quality. Some suspension companies will put plastic "slipper pads" in between the leaves to help with movement. On several occasions I've actually took an existing suspension that rode terrible disassembled it recondition everything with new bushings and bolts took apart and reassembled spring packs, new shocks and it was like a new truck. Make no mistake about it, it's a lot of labor.
« Last Edit: September 24, 2014, 11:07:19 am by pholliday1 »
« Reply #20 on: October 04, 2014, 02:23:37 pm »
He's good to go. Got him back about 2 weeks ago. When I get time I'll post a picture of what the nut looked like on the front eye of the rear spring. I've never seen something like it before so I thought others might enjoy it. I appreciate all your input.
