Author Topic: 1976 Factory Tach - Dead?  (Read 20035 times)
Offline 76LongBox
Re: 1976 Factory Tach - Dead?
« Reply #15 on: October 27, 2014, 06:39:09 pm »
Update:
I received my new tach circuit board from Willcox today....I now have a working tachometer.
I did not have a way to bench test it and set it so that I know it's 100% accurate, so what I did was used my timing light that reads RPMs to see if it was at least close.  I tweaked the potentiometer on the new circuit board a little bit, and I think it's now close enough for my purposes.
Offline sphinx
« Reply #16 on: October 31, 2014, 06:33:03 pm »
Sounds good.  Hope it works great.
Offline BlackTomC
« Reply #17 on: April 21, 2015, 06:58:27 pm »
@76LongBox
Did that board end up fixing your issue? I am currently experiencing a similar problem except my tach reads slow/under what the actual RPM's are.
The bottom line has dropped
