Author Topic: TPI complete transplant, 83 k10  (Read 113385 times)
Offline LTZ C20
Re: TPI complete transplant, 83 k10
« Reply #90 on: December 07, 2014, 02:33:21 am »
Track down the wires from the injectors back to find out where they go.
You should be using the vette harness for the distributor, the only wires from the truck that need to go to the area are the "Batt" and "Tach" wires from the truck side. The truck should have a Batt wire that went to the distributor or ignition coil,  it needs to go to the same place on the vette ignition coil. Then Tach to Tach obviously if you have a tach. Use the truck wiring to go to the starter, should be a POS battery cable, and then a few wires, one being from the ignition switch to start the truck, and the other standard starter wires, I think there's 3 in total. The vette harness should have a wire that goes to the starter that gets energized when you start the truck, should be on the same post as the ignition switch wire, this tells the computer that your starting the engine.
That's the way it works on my TBI setup, I may be wrong but I think it works the same on TPI, maybe Capt will chime in again.
LTZ Cheyenne C20
Offline Brocksdad1
« Reply #91 on: December 07, 2014, 08:01:03 pm »
Well I found all the wires that I need to go to my new fuse box I'll buy tomorrow.
Got the wires separated, figured out.
I'll route them through the firewall tomorrow.
I have to order the prom though.
I've heard about burning your own. Anyone here done that. Seems that it cost as much to buy the stuff to burn as it does to buy one burnt. From what little I have read.
Also need to find out the proper belt length for removing the smog pump.
I think me not feeling well got me flustered. But I'm back on track now.
God,Family,Fishing,Cardinals baseball,Chevy trucks
Offline LTZ C20
« Reply #92 on: December 08, 2014, 01:44:08 am »
Ok cool. Glad you got it figured out. Not feeling your best can really mess up your wrenching skills, I know I've tried to wrench and just had to stop if I was sick cuz it don't work when your feeling ill. What fuse block are you getting?
One day I would like to get all new wiring for my truck, even tho I know alot of it is still good, alot of it is also not. One day I would like to get the harness from a 90s or maybe mid 2000s truck with all the normal stuff, cruise, ac, power doors and windows and power seats, sterio and just re wire the truck and just splice in the trucks original wiring where needed, for the cluster and steering colum and light plugs and such.  Would like to move the entire fuse block to under the hood, every single fuse and relay I can get there, I would like it all at one place under the hood in one nice neat box. But that's another topic for another day.
Anyways, on with your current project!
« Last Edit: December 08, 2014, 01:47:47 am by LTZ C20 »
LTZ Cheyenne C20
Offline fitz
« Reply #93 on: December 08, 2014, 10:01:02 am »
  I've never burned my own chips, and unfortunately I can't find anyone locally who still works with  TPI chips to have one done.
  I looked into a company called Fast Fuel Injection. They make a stand alone harness for TPI systems (my truck has a painless wiring harness) with its own self tuning computer. This system eliminates the need to burn chips.
  The system cost about $900.  It's more money then getting a mail order chip (about $200) but is seems like a decent option if you plan on any engine modifications down the road.
Offline Brocksdad1
« Reply #94 on: December 08, 2014, 03:44:26 pm »
I'm just getting a sealed 6 bank blade style fuse box from a company called Hutchinson here in Evansville. It's more than I need but I might need some more later.
I think I might just get a prom from Tpiparts.com that is VATS delete and maybe stage 1.
Offline LTZ C20
« Reply #95 on: December 09, 2014, 12:18:58 am »
Oh ok. Cool cool. Don't forget about Howell Engine Development.
LTZ Cheyenne C20
« Reply #96 on: December 09, 2014, 06:48:30 pm »
You want switched power to come from the truck harness.  As it is connected to the switch.  The Vette harness should control the motor.
Offline Brocksdad1
« Reply #97 on: December 09, 2014, 06:50:02 pm »
Yes exactly I'm right with you
Offline LTZ C20
« Reply #98 on: December 09, 2014, 07:22:26 pm »
Where are the pics man?! I wanna see this thing haha.
LTZ Cheyenne C20
Offline Brocksdad1
« Reply #99 on: December 09, 2014, 09:30:02 pm »
I had posted one.
Here it is.
I'll get more.
Offline LTZ C20
« Reply #100 on: December 10, 2014, 12:52:42 am »
Yea saw that one already. You have us hoping for more
LTZ Cheyenne C20
Offline Brocksdad1
« Reply #101 on: December 10, 2014, 08:00:44 pm »
Ok so my hip has been killing me so no other work has been done. But I have some more install pics and a list of parts with numbers bought so far. Ill put a list together at the first page eventually
this is the pile of wires I started with for the under-dash connections this is what I am now left with before taping and fuse box and connection most all of this that is laying over the booster will go, its vet harness that isn't needed Ill have plenty of room for the Vet fan I scored from the donor car just teaser shotsheadman 69099 headersheadman collector 21143 with 02 bungRPC SPEED SENSOR
Parts
Headers he-69099
Collector he-21143
Speed sensor RPC-250-4153
Now these are all Summit numbers, so Im not sure if they are the same everywhere.
BRYCE
« Last Edit: December 10, 2014, 08:04:14 pm by Brocksdad1 »
Offline LTZ C20
« Reply #102 on: December 12, 2014, 12:08:50 am »
Good work so far! That's what we like to see. Looks good so far. The engine looks good sitting in there.
LTZ Cheyenne C20
Offline Brocksdad1
« Reply #103 on: December 12, 2014, 07:26:02 pm »
Here's an update for you
Got the wires through the firewall and ready to plug into the fuse panel I got today
Offline LTZ C20
« Reply #104 on: December 12, 2014, 08:13:26 pm »
Nice. Have you decided where you are gonna put the ECM? In factory mount?
LTZ Cheyenne C20
