Author Topic: What did you do with your truck today?  (Read 53454 times)
Offline Kren420
  • 1986 C10 Silverado
Re: What did you do with your truck today?
« Reply #30 on: December 04, 2014, 01:32:26 pm »
Got some new winter tires for the truck today!  Nokian Hakkapeliitta's.  They seem very good.
Offline roundhouse
« Reply #31 on: December 05, 2014, 02:39:41 pm »
That's a easy to pronounce name
They from china ?
Offline Ben_Greenberg
« Reply #32 on: December 05, 2014, 03:43:02 pm »
They from china ?
I believe they are from Finnland and they specialize in winter tires. Supposed to be the best non-studded winter tire available.
Offline Brocksdad1
« Reply #33 on: December 06, 2014, 02:18:43 pm »
I got my wire harness ready to go through the firewall this morning, but I think I might have the stomach flue
God,Family,Fishing,Cardinals baseball,Chevy trucks
Offline fitz
« Reply #34 on: December 06, 2014, 04:02:06 pm »
  The wiring on my TPI set up gives me that quesy feeling too. Hang in there, you have made great progress so far.
  I'm looking forward reading about your truck as the project continues.
Offline frotosride
    • WFO CONCEPTS
« Reply #35 on: December 06, 2014, 05:35:04 pm »
Finally got the radiator fans and shroud one plus a new water pump. the old one was squeeeelin.. we all know that is one of the first signs of bad bearings. it ook it out and the old pump had no drag at all. Ran the old man through a few heat cycles and so far no leaks first try...well not the first time so I guess that counts for something. Brock.. gonna check out your progress on that TPI.
Offline Kren420
« Reply #36 on: December 08, 2014, 08:31:53 pm »
They from china ?
That is correct!  At least according to the tire shop.
Offline Brocksdad1
« Reply #37 on: December 08, 2014, 09:18:09 pm »
Found the color scheme I'm going with
« Reply #38 on: December 08, 2014, 10:10:08 pm »
Whoa baby! When you're done we better see that on here!
Offline Brocksdad1
« Reply #39 on: December 08, 2014, 10:12:23 pm »
It's gonna be on my 83. It's Brown and Tan. Gonna have slate grey interior. Btw I'm collecting interior parts.
Is there a for sale section?
Offline roundhouse
« Reply #40 on: December 09, 2014, 06:07:24 am »
Dropped the gas tank to install a new one
Old one is leaking and has some problem where if you run it of of gas you have to put over 10 gallons in to get it to draw gas again
Also installed new stock grill to replace tube grill
Got the body bushings and  4 brand new door hinges and a new speedo cable in the mail too
Only took 3 trips to the hardware store to get the grill installed
And had to run a thread cutting die down on the tank strap bolts to get the threads clean enough to remove the bolt
Glad I just dropped the hanger and all out to begin with
Discovered that the o ring around the sender was leaking
And the filler tube is a poorly fitting radiatior hose
« Last Edit: December 09, 2014, 06:10:23 am by roundhouse »
« Reply #41 on: December 09, 2014, 09:27:50 pm »
took my 91 v3500 crew cab on a 200 mile trip one way with a 4 wheeler in the back to my uncles house. i delivered the 4 wheeler to mineral va (where we had the earthquake at a couple years ago). last year i had a run in with a local not real bad but they aint to fond on Yankees. but this time showing up in the crew cab and 4 wheeler in the back with my family and luggage in the front wearing camo. i pulled up to a stop light next to a guy in a light dump truck, i opened my door and dumped my spit cup and just happened to look up at the guy right about the same time my wife was looking at what i saw. the guy was watching me then he gives me a nod of approval and spits into his cup. me and the wife lost it and i told her i think they have accepted me as one of their own and i blend in real good
Offline frotosride
    • WFO CONCEPTS
« Reply #42 on: December 10, 2014, 07:55:20 pm »
Irish..the hills really do have eyes! You just met them. But sounds like HOME to me!  ;D
Today I drove all over east Va looking for tie down anchors to load one of my bikes (650lbs). Found some track style ones with a 2200lb break weight and 1200lb working weight. The are in with some nutserts so I can re!move them whenever even though they are low profile and I doubt I will ever need to take them out!
« Reply #43 on: December 14, 2014, 01:45:26 pm »
Checked the oil in my 84... crap, it went through a quart in 400 miles, dipstick is milky white and the radiator is down.  Guess I need to step up the search for a replacement power plant.
Offline DuckAholic1
« Reply #44 on: December 15, 2014, 03:17:37 pm »
On sunday...Tore apart dash to replace burnt out bulbs, replace two gauges, speakers, cleaned all connection points. Almost halfway done! Darned work is in the way the next few days!!
