Author Topic: Section frame to raise crossmember?  (Read 11482 times)
Offline Mtrhd329
Re: Section frame to raise crossmember?
« Reply #15 on: January 10, 2015, 10:26:13 pm »
I pushed the sway bar towards the back of the truck with the bushings loose and then i had room to mount it to the frame.  The ends of the bar stick through to make contact with the coil so i will have to trim the slightly bit i got my sway bar on there!
