Author Topic: My build  (Read 39107 times)
Offline JoshsC10
Re: My build
« Reply #30 on: December 26, 2014, 03:04:05 pm »
Hey I'm fixing to order lowering kit, how do I measure the rotor size? Just the thickness of rotor? Thanks
Offline 78BIG-TEN
Re: My build
« Reply #31 on: December 26, 2014, 05:09:39 pm »
For drop spindles you need to know if they are 1 inch wide or 1 1\4
Re: My build
« Reply #32 on: December 27, 2014, 12:11:47 pm »
Measure the width of the rotor and post the dimensions
Offline JoshsC10
Re: My build
« Reply #33 on: December 27, 2014, 12:32:10 pm »
It's 1" thick. But now I have new problems, I'm having worst luck with power steering leak it keeps spraying out of the line where it's attached to steering box happened three times now. I'm gonna have to get a new hose I think.
Offline JoshsC10
Re: My build
« Reply #34 on: December 29, 2014, 01:03:53 pm »
Got lowering kit ordered supposed to b here on Saturday. Would it be easier to do the rear if I removed the bed?
Offline 78BIG-TEN
Re: My build
« Reply #35 on: December 29, 2014, 03:57:25 pm »
Some hoses were flare and some used an o-ring.I think yours is o-ring style
Re: My build
« Reply #36 on: December 29, 2014, 07:46:31 pm »
Removing the bed will make it easier.  What kind of kit did you get for the rear?
squarebody.biz
Offline JoshsC10
Re: My build
« Reply #37 on: December 29, 2014, 10:41:28 pm »
Flip kit for rear.
Re: My build
« Reply #38 on: December 30, 2014, 11:25:57 am »
Are you getting a bolt in notch?  If so remove the bed.
Offline JoshsC10
Re: My build
« Reply #39 on: December 31, 2014, 09:56:17 am »
I think I will remove bed, here's a few pics from yesterday got exhaust ran out sides
Offline JoshsC10
Re: My build
« Reply #40 on: January 01, 2015, 11:37:30 pm »
Offline JoshsC10
Re: My build
« Reply #41 on: January 02, 2015, 10:08:28 pm »
Well I'm installing c notch kit now, went to remove leaf springs and the 3rd one is broken on both sides do u guys think it would be a bad idea just to remove it completely? Thanks
Re: My build
« Reply #42 on: January 03, 2015, 02:17:14 am »
how many leafs in the pack?  If 5 you can remove it.  If 3, I wouldn't recommend removing it without replacing it.
Offline JoshsC10
Re: My build
« Reply #43 on: January 03, 2015, 09:35:37 am »
Only 3
Offline JoshsC10
Re: My build
« Reply #44 on: January 03, 2015, 05:44:37 pm »
Got c notch finished last night
