Author Topic: 1985 k10 horn cig dome and curtassy lights not working  (Read 21165 times)
Re: 1985 k10 horn cig dome and curtassy lights not working
« Reply #15 on: January 13, 2015, 09:30:41 pm »
Sounds like you still have a short.  Have you traced the wires?
Offline true74yamaha
« Reply #16 on: January 14, 2015, 12:46:56 am »
I went threw the only place it could be is behind the gauge cluster where the wires come from the relay go up and over to go to the fuse panel.  I don't see why Id have a short there.  I was told that it has to be in the #240 circuit and it has to be out of the column sense the fuse pops right after being installed. Why also would my tail lights work but dome nothing? I do have a periodic short in the left one.  I think this is due to some rust under grounding screw behind the tail light bucket.  I would've cleaned it up and removed the rust I just didnt have sand paper handy.  Also dunno if I mentioned.
I pulled fuse and oem horn relay. I installed new fuse with relay out and fuse was fine.  As soon as I installed my new relay the fuse popped. Obviously a short caused this but where in the system would I look?   Also can someone post a pic of their fuse panel to make sure my wires at the top look like they are installed correctly please.
« Reply #17 on: January 14, 2015, 02:48:28 pm »
Used test light went from 204 circuit in relay side aka orange wire with a good  fuse in relay out.  Fuse didn't pop and the light came on.  Went ground to cig hot # 204 came on with relay out.  Does this mean column has a short?
« Reply #18 on: January 14, 2015, 06:17:48 pm »
Well the gm Gods thought they'd quit toying with me and show me the light or sound!!!
My truck needed a cigarette lighter dome light wiring fixed (haven't checked bulbs for curtassy lights maybe bad). After two relays and a few fuses, I hurd a click click from my relay when I pressed the horn button.  I then proceeded to remove the grille and hooked up my dr side horn a slight spark happened. Then proceeded to my LH horn and did a bigger spark and blew my fuse. I thought weird.  I disconnected my horns and tested them hooking up to the battery and my horns didn't work.  This was weird as I use to have them on a push button that I riged up in the cab. After the horns didn't work I went over to my work bench grabbed a old motor cycle horn and hooked a wire to the battery for a good ground and the other to my oem horn hot wire connector.  I then went to the cab hit my horn button on the column and to my surprise my horn blared.  I still think it's crazy that both my hi and low horns went to crap.  But some how worked intermittently.
Offline Jason S
« Reply #19 on: January 14, 2015, 09:12:35 pm »
That is good news!
It is very interesting to hear about both horns shorting out...
