Author Topic: Headlight troubles  (Read 15656 times)
Offline Ds2014
Re: Headlight troubles
« Reply #15 on: January 19, 2015, 02:04:05 pm »
I'll change them when I get home but I don't think that would be the problem. Captkaos, I found a relay wiring diagram on here for the headlights, it made them a lot brighter
Offline Ds2014
« Reply #16 on: January 22, 2015, 08:31:10 pm »
Still no progress,it's killing me I have a groung from bat to chassis to radiator support to lights
Offline Ds2014
« Reply #17 on: January 23, 2015, 03:34:58 pm »
And all T's flash when left blinker on right only when right blinker
« Reply #18 on: January 24, 2015, 10:30:55 am »
I think I am confused.  What is the problem now?  What is T's?  Turn?
Offline Ds2014
« Reply #19 on: January 24, 2015, 04:44:27 pm »
Sorry t/s turn signals
« Reply #20 on: January 26, 2015, 07:38:17 pm »
So when the Left turn is selected all turns flash?
Offline Ds2014
« Reply #21 on: January 26, 2015, 09:25:13 pm »
Yes. Unless the headlights are on,then they all just get bright
« Reply #22 on: January 27, 2015, 01:13:30 pm »
I would check your wiring, you got something crossed.
Offline Ds2014
« Reply #23 on: January 31, 2015, 09:02:34 pm »
I fixed the blinker Prob,it was a bad socket and the wires were crossed.  The headlights,hi beams still dim on low beam   That's on the agenda tomorrow
Offline Ds2014
« Reply #24 on: May 25, 2015, 05:02:54 pm »
I have an81 stepside when I turn the head lights on all four lights come on, the top two are really dim lower two bright,when I turn the hi-beams on all four are really bright. Now are the three prong bulbs the hi or the low?
Offline Ds2014
« Reply #25 on: May 25, 2015, 09:48:24 pm »
I just checked bolts on the hi-beam bulb and I have 9 when low beam is selected. Can any one shed light on this??
« Reply #26 on: May 26, 2015, 12:57:09 am »
The 2-prong bulbs are high beam.  The 3-prong bulbs are low and high beam.  The upper lamps should be the low/high beam pair.
The symptoms suggest poor ground connections.  Unplug all the headlamps and wash the connector terminals with WD-40.  Plug each connector back up to its headlamp and unplug it several times, repeatedly, to clean the connections.
Factory wire colors are:
  • Green - high beam
  • Tan - low beam
  • Black - ground
Make sure each headlamp is properly grounded to the steel radiator support through its black wire.  Then make sure the radiator support is grounded directly to the battery.  You may need to disassemble the ground wire connections to the sheetmetal and clean them thoroughly to shiny bare metal using sandpaper.  Reassemble with a liberal coating of antioxidant paste.
Offline Ds2014
« Reply #27 on: May 26, 2015, 03:43:08 pm »
I cleaned all the grounds now it's dimmer I'm going to buy new headlights all the plugs are new
« Reply #28 on: May 26, 2015, 05:16:03 pm »
Are you running the factory style sealed beam headlamps?  Although it's true that lamps gradually dim with use, you also could have wires crossed at the back of the low beam lamps.
