Author Topic: 1975 K-10 Project  (Read 214105 times)
Offline BBM3
Re: 1975 K-10 Project
« Reply #165 on: September 21, 2015, 07:01:53 pm »
So much for no leaks.
I drove the truck hard for over 100 miles the other day. Far more than I have driven it since I bought it.
The NP205 transfer case weep is now a full on leak. A big one.
I have UV dye and a UV flashlight coming on Wednesday that I'm going to use before I start wrenching.
Hopefully just output shaft seals however I foresee this turning into removal and a full rebuild.
Offline enaberif
« Reply #166 on: September 21, 2015, 08:11:47 pm »
Most of the time it is in fact the output shaft seals. The front one on my 203 is leaking like a stuffed pig lol
Offline BBM3
« Reply #167 on: September 26, 2015, 03:25:39 pm »
I removed the transfer case today.
The final inch happened a bit faster than I would have liked.
For sure I will be renting or buying a transmission jack to reinstall it.
Offline LTZ C20
« Reply #168 on: September 26, 2015, 03:35:41 pm »
That thing is disgustingly dirty and gross lol definitely a good thing that you pulled it out.
LTZ Cheyenne C20
Offline BBM3
« Reply #169 on: September 26, 2015, 04:17:48 pm »
There is at least a 1/4 inch of dirt on the top most of which is just a bit softer than 40 year old concrete.
I didn't pull it out as much as dropped it out. Thankfully the only damage was to the speedometer reducer and my ego.
It's not going back in without a helper, transmission jack, and tie down straps.
Offline LTZ C20
« Reply #170 on: September 26, 2015, 07:53:48 pm »
I found similar concrete type dirt on my crossmember when I had the engine out of mine. I also almost dropped a torque converter on my feet when I was pulling the TH350 out when I was swapping to the 4L60. Those kinda things have a way of getting your attention in about 0.002 seconds haha.
LTZ Cheyenne C20
Offline BBM3
« Reply #171 on: September 29, 2015, 05:26:38 pm »
This is better.
Ready for a fresh coat of paint and reassembly. I can't decide on color. Chevy orange, gloss black, or other?
Offline enaberif
« Reply #172 on: September 29, 2015, 06:41:57 pm »
Black or Dark Gray.
Also I wouldn't be putting that back together without a twin stick setup.
« Reply #173 on: September 29, 2015, 08:31:29 pm »
Offline enaberif
« Reply #174 on: September 29, 2015, 08:34:58 pm »
Tremclad hammertone. The stuff looks really sharp when done properly.
http://dino246blog.blogspot.ca/2011/02/radiator-fan-motor-restoration-giving.html
Offline LTZ C20
« Reply #175 on: September 29, 2015, 09:28:42 pm »
I'd say Yea either matte black or grey, if it was me I would either do just medium grey or aluminum grey.
LTZ Cheyenne C20
Offline Don5
« Reply #176 on: September 30, 2015, 01:23:55 am »
Did you clean that TC in your parts washer? It looks really nice. Ready for paint. I am going to have to take mine out and go through it someday. I am sure it could use a good rebuild.
Offline BBM3
« Reply #177 on: September 30, 2015, 10:46:28 am »
Thanks for the suggestions everyone.
I decided to go semi-gloss black since I already have 2 cans.
http://duplicolor.com/product/engine-enamel-with-ceramic
I use this paint on shotgun receivers I convert and it has proven to be really tough.
Black or Dark Gray.
I seriously considered a twin stick but I don't think I'll use it enough to justify the cost.
Yes I used my HF parts washer with full strength Purple Power in the tub.
I did find the Purple Power oxidizes aluminum pretty quickly. Not a good idea to soak aluminum in the stuff.
I was surprised to find no real wear in my TC only a little on the shift forks. Even the yokes have virtually no seal wear and the new improved seals touch the yokes in a different place.
Offline BBM3
« Reply #178 on: September 30, 2015, 04:31:14 pm »
Hope I can remember how to put it back together. :)
Offline enaberif
« Reply #179 on: September 30, 2015, 04:36:02 pm »
There is a REALLY good set of videos on youtube about the 205 assembly if you get stuck. Looks good though.
