Author Topic: Engine not warming up, heat not hot  (Read 11674 times)
Offline 78BIG-TEN
Re: Engine not warming up, heat not hot
« Reply #15 on: February 13, 2015, 08:48:46 am »
A working thermostat should keep the engine at a pretty constant temp.Too much flow thru the heater could cause it to run cooler.Most Chevy's use a restrictor fitting in the heater hose usually the fitting in the manifold.It should have about a 3\8 hole and not wide open 5\8.After all the heater core is nothing more than a radiator
