Author Topic: Timing answer for 2013DartR  (Read 19151 times)
Re: Timing answer for 2013DartR
« Reply #15 on: April 10, 2015, 08:59:50 pm »
Offline rich weyand
« Reply #16 on: April 11, 2015, 10:15:23 am »
Went to install the distributor today and I've got problems. Apparently mine is a 5 pin ignition module which has its own set of wires leaving the distributor straight back to the firewall. The distributor that I bought is a 4 pin and has no use for these wires. Now what? Can the Electronic Spark Control be abandoned? It doesn't appear to connect to anything except the distributor and detonation sensor.
If you bought a new HEI distributor, all it needs to connect to is switched +12V at the BAT terminal.  That's it.  The other connector to the cap comes out of the distributor base itself.  You just need to hook the BAT terminal to switched +12V, which is to say IGN on the fuse block.
Offline 2013DartR
« Reply #17 on: April 11, 2015, 12:31:51 pm »
Got everything in the front hub put back together and decided to do the distributor. Everything went well. Got the timing set. Has knock at wot. That should come out with adjusting the vacuum advance. Only problem I have now is hesitate off line. My guess is carburetor adjustments. Any guesses? I appreciate and thank all of you that have helped so far.
81 Chevy K-10 305, Holley 4175 carb, with an 85 700r4 trans
Offline FlatBlack77
« Reply #18 on: April 11, 2015, 02:02:23 pm »
what did you set the timing at and what octane fuel are you using?
also is the advance connected to manifold or ported vaccume?
Offline rich weyand
« Reply #19 on: April 11, 2015, 05:26:23 pm »
The WOT knock will not come off with vacuum advance adjustment.  You need to back the base timing off.  What are you set at now?  Back off a couple degrees at a time untill there is no WOT knock.
Don't bother adjusting the vacuum advance.  Stock is 15* and that's fine.  It's not that picky.
Vacuum advance should be connected to manifold vacuum.  An off-idle hesitation sounds like you have it on ported vacuum.  You sure it's on manifold vacuum?
Offline rich weyand
« Reply #20 on: April 11, 2015, 05:28:36 pm »
The other common cause of off-idle hesitation is an inadequate shot from the accelerator pump.  When the throttle plates open, the air moves immediately, and it takes a while for fuel flow to catch up, so carbs shoot a jet of extra gas in there for a second or so when you open the throttle.  If that isn't working, you will get that hesitation.
Offline 2013DartR
« Reply #21 on: April 11, 2015, 07:24:07 pm »
Ok, I won't touch the vacuum advance. I didn't get a chance to work on it again this afternoon, so I haven't touched anything except timing. Timing is set at 14 degrees. So I should take that back to 12 degrees? I am guessing that vacuum is attached to a manifold port off the carb. It is the one Rich told me to connect to. As for the octane rating I use regular which I think in MD is 87.
Offline rich weyand
« Reply #22 on: April 12, 2015, 09:28:55 am »
Yeah, knock it back to 12.  Knocking on WOT is not good for the engine.
Post a pic of the carb showing the vac advance connection.
Check the operation of the accelerator pump.  Remove the air cleaner.  With the enging off, look down the bore of the carb, and with your hand advance the throttle to full open and hold it there.  There should be a jet of gasoline that you can see into the bore that lasts a second or two.
Offline 2013DartR
« Reply #23 on: April 12, 2015, 06:55:21 pm »
Here are the carb pics. In first pic the hose that looks like it is going to the orange emissions thing actually loops back to the vac on the distributor. I'll have to clean up the vac lines tomorrow. All the emissions is gone except for the pcv and egr. All the lines coming off the carb are plugged just long so I'll pull them all off and plug at the carb.
« Last Edit: April 12, 2015, 07:16:18 pm by 2013DartR »
Offline rich weyand
« Reply #24 on: April 12, 2015, 07:58:42 pm »
Keep the PCV, it's important.  It allows the carb to suck blow-by out of the crankcase and keep it from turning into sludge in your engine.
Vacuum advance is hooked up properly.
Check that accelerator pump operation.
Offline 2013DartR
« Reply #25 on: April 12, 2015, 08:01:57 pm »
Ok I'll check that hopefully tomorrow. I think the PDF document you gave me early talks about that. Thanks again and I'll keep you posted.
Offline 2013DartR
« Reply #26 on: April 13, 2015, 07:29:39 pm »
Reset the timing to 12 and that took the knock out. Started working on the accelerator pump today and found one of the accelerator pump arms stuck on the shaft. Finally out that unstuck and greased up. That helped some at least the pump arm wouldn't stick down. Still have to try some adjustments on the pump and possibly new larger squirters.
Offline 2013DartR
« Reply #27 on: April 20, 2015, 07:06:43 pm »
So, I ordered a new squirter (discharge nozzle), accelerator pump arm, accelerator pump arm stud, and some new accelerator cams. Replaced all of that because the arm stud was rusty and making the pump arm(plastic replaced with a metal one) stick, the squirter was a #37 and should have been a #31, and the cam was an orange and should have been a green. Everything seems to be running great now, no hesitation. Thanks to everyone that helped with this I really appreciate it and hopefully someone else can use this information. ;D
Offline rich weyand
« Reply #28 on: April 20, 2015, 07:26:01 pm »
Excellent.  Thanks for reporting back.
