Author Topic: carb help on new to me suburban  (Read 20257 times)
Offline stretch86
Re: carb help on new to me suburban
« Reply #15 on: April 02, 2015, 12:54:59 pm »
The thing that puzzles me is the old plugs were a good tanish color
Offline stretch86
« Reply #16 on: April 02, 2015, 01:31:34 pm »
My uncle has a new quadrajet that was for a 86 cutless with a 307 would that fit work on my truck
« Last Edit: April 02, 2015, 01:33:51 pm by stretch86 »
« Reply #17 on: April 03, 2015, 12:22:14 am »
start by double checking your firing order and use a timing light and see what ° your timing is at.
Offline stretch86
« Reply #18 on: April 04, 2015, 03:19:09 am »
I had a guy come over today and help me with carb determined old carb was junk so put on another one that had gotten with truck. Theres a vacuum port on choke housing where does it go cause it fired up before drove it around then let it sit for a couple of hours and wouldnt start. Ended up opening chokes plate and it fired right up its like it was giving it to much choke and engine was still lil warm. I can post pics later  if needed.
Offline stretch86
« Reply #19 on: April 04, 2015, 03:22:23 am »
Also the engine ran great best that ive heard it run and throttle was very responsive no hessitation or anything
Offline Greybeard
« Reply #20 on: April 05, 2015, 04:06:56 pm »
I agree with the pros here, make certain the electrics work right first, then check for vacuum leaks, last would be the carb. Otherwise, you are chasing your tail.
Offline Stewart G Griffin
« Reply #21 on: April 12, 2015, 03:11:26 pm »
Also the cutlass carb won't work very well on the truck because it's computer controlled.
Offline Greybeard
« Reply #22 on: June 12, 2015, 02:21:20 am »
And even though this thread is likely starting to rot it's been dead so long, I want to say I totally agree with what Stewart said. I had an 85 Blazer with the electric Rochester, I did the ignorant stuff to it, unhooked all the smog crap including the electrical connecter to the carb. The truck ran, but it ran like crap. It was a 305. It went from helpless to pointless. I unloaded the truck after that it was so rusted out and the tailgate wouldn't open. The new owner put a Holley on it and cut the tailgate off and ran it for a few years more until the body literally fell off the frame.
Offline stretch86
« Reply #23 on: June 12, 2015, 11:48:25 am »
Eventualy i wanna get different motor for the body isnt that bad for being 30 years in nh and the frames in great shape. Ive capped off vac ports on carb and it does run great good throttle but its diffucult to start at times especially when trucks warm ive also added a manual choke to it as the auto choke kept acting up. My plan is to get a vortec 350 with a nv4500. Build the vortec up a lil bit and fix body with new panels. I also understand the difficulties thats gonna come with adding the nv4500 but thankfuly i found a write up some one did for there 89 3/4 suburban. All in all theres a lot ive gotta do to it and gonna do lil at a time when money and time permits me to.
Offline stretch86
« Reply #24 on: June 12, 2015, 11:50:47 am »
Offline rich weyand
« Reply #25 on: June 12, 2015, 01:28:20 pm »
It would help a lot if you put the original-style air cleaner back on and got rid of the two-chrome-pie-plates nonsense.
Offline stretch86
« Reply #26 on: June 12, 2015, 01:45:58 pm »
Cant dont have it and im having a heck of a time finding a rear end for it
« Reply #27 on: June 14, 2015, 08:13:57 am »
What's your start up procedure?
Offline stretch86
« Reply #28 on: June 14, 2015, 02:12:10 pm »
When its cold ill pump it couple of times and pull choke when its warm i forgot what i did cause its been couple months since driven it cause of rear end
Offline hatzie
« Reply #29 on: June 16, 2015, 10:46:02 pm »
I always pushed the throttle to the floor twice to prime the intake and set the throttle on the high idle cam. Then I cranked it over.  She always kicked right off.
If you have an electronic feedback carb you want to keep all of the smog crap hooked up including the original air cleaner.  To dump the smog stuff you need an earlier carb and intake. It'll run like garbage otherwise.
From orbit on my Android.
