Author Topic: cab light?  (Read 36277 times)
Offline vr4oaks
Re: cab light?
« Reply #15 on: April 17, 2015, 08:34:27 am »
Here's a quick link to the various manuals. Scroll down for the wiring diagrams and select the year model of your truck.  The wiring for the dome lamp is fairly simple.
http://forum.73-87chevytrucks.com/smforum/index.php?topic=30115.0
Thank you! Just what I wanted.
-vr4oaks
1979 Chevy c10, Super HX30, POD Injectors, Timing and Fuel turned up, FASS 15 PSI Fuel Pump, BHAF, Autometer Pro-Comp 2 Boost and EGT gauges, 4" MBRP Dodge Cummins Exhaust, 12" 273 welded rear-end, max boost 40 pounds, max EGTs 1500, Hydroboost
