Author Topic: Radiator Fan  (Read 75125 times)
Offline Don5
Re: Radiator Fan
« Reply #60 on: June 17, 2015, 09:25:53 pm »
BTW- my 79 came with a fixed blade fan and I replaced it with a clutch fan. I have never had the issue that you are having. I also did have a brand new thermostat stick shut on me the very first time I fired a new engine up. You might have to get another thermostat. Yours might be defective.
My shroud dimensions are: 7 blade fan, shroud is 7 inches deep, the fan blades are inside the shroud 1/2 inch and the inside diameter is 22 inches + or - a little bit.
Offline enaberif
Re: Radiator Fan
« Reply #61 on: June 17, 2015, 09:33:11 pm »
I put a 190 into it. But using a infrared gun the water neck never gets over 170-175* F
I am going to put a block off plate so less air gets to the water neck to see if it helps.
« Last Edit: June 17, 2015, 09:35:18 pm by enaberif »
Offline LTZ C20
Re: Radiator Fan
« Reply #62 on: June 17, 2015, 10:31:52 pm »
195 is stock temp. Maybe a 200 or 210, I know it's higher but maybe it will compensate and get you up too the proper temp. Besides, a 350 will run 210 no problem.
LTZ Cheyenne C20
Offline enaberif
Re: Radiator Fan
« Reply #63 on: June 17, 2015, 10:50:00 pm »
Sorry yah its a 195 lol.
Offline timthescarrd
Re: Radiator Fan
« Reply #64 on: June 17, 2015, 10:50:51 pm »
If the thermostat isn't opening, then coolant is never exchanging between the block and the radiator, so your water neck will always be the temp of the coolant in the radiator.  I would use your thermometer to check the temp of your intake and heads.
The only way the fan can be over-cooling if the thermostat is not opening, is if it is pushing enough air over the block to air-cool it (like a motorcycle or old VW engine).  If that's the case, I would begin to suspect how well the engine is running
Re: Radiator Fan
« Reply #65 on: June 17, 2015, 10:53:14 pm »
These may sound ludicrous, but (1) how are the heater hoses plumbed, and (2) what happens if you pinch off the heater hoses?
Offline enaberif
Re: Radiator Fan
« Reply #66 on: June 17, 2015, 11:27:55 pm »
Well ironically when I pull the fan off the thermostat will open just fine and work as normal. What would cause a vehicle to not run right to cause this though? You are basically saying the engine itself is running cool.
The proper way... 3/4 to pump
I will check the temps of the heads on the next test.
Offline Don5
Re: Radiator Fan
« Reply #67 on: June 18, 2015, 12:14:59 am »
Top hose goes to the water pump and the bottom hose goes to the intake. I know you know but just so you don't get confused. Just tryin to help. :)
Re: Radiator Fan
« Reply #68 on: June 18, 2015, 01:51:19 am »
So does clamping off coolant flow through the heater have any effect whatsoever?
Offline enaberif
Re: Radiator Fan
« Reply #69 on: June 18, 2015, 06:34:36 am »
Haven't tried yet. Curious what this will accomplish?
Re: Radiator Fan
« Reply #70 on: June 18, 2015, 09:44:13 am »
Usually an engine will run cooler than normal if it's running rich, it's not firing all cylinders, or the outside ambient temp is very low.
Being June, we'll assume it's not below freezing outside. Running that rich I would expect you'd notice black smoke from the tailpipe.  I've seen engine run on only one bank and still feel fairly smooth, so you might check the temp of the exhaust manifold near each valve, those should be decently consistent.
Re: Radiator Fan
« Reply #71 on: June 18, 2015, 09:48:50 am »
kind of going of what tim said but just curious whats your timing set at?
Offline enaberif
Re: Radiator Fan
« Reply #72 on: June 18, 2015, 10:19:44 am »
You would be correct and on most days lately its been well above 15 degrees celsius. No black smoke to be seen at all and I will definitely check the exhaust manifolds to see what they say.
Right now its running at 16* BTDC.
Offline enaberif
Re: Radiator Fan
« Reply #73 on: June 18, 2015, 07:12:29 pm »
Ok so I did some testing.
Truck warmed up and running for 30 minutes.
Cylinder temps on the head just above the ports is betweem 280-380 with 7 and 8 running cooler.
Water neck gets up to 182-185. If I wrap the water neck with insulated bubble wrap I will seen a immediate increase in temps of 193-195
Also water pump pulley is smaller than the crank pulley. Water pump pulley is 6.25" and the crank pulley is 6.75-7"
So by wrapping the water neck I am seeing a 10 degree increase of temps which leads me to believe my fan is blowing too much cold air.
« Last Edit: June 18, 2015, 08:19:10 pm by enaberif »
Offline LTZ C20
Re: Radiator Fan
« Reply #74 on: June 18, 2015, 09:24:26 pm »
Water pump pulley being smaller than crank pulley is normal.
LTZ Cheyenne C20
