Author Topic: Guess the sound  (Read 40287 times)
Offline Chisholmcody
Re: Guess the sound
« Reply #15 on: May 19, 2015, 06:15:00 pm »
I got the starter replaced it sounds better when cranking and cranks faster but ...... The motor won't start no matter what I do. I have spark but when it's cranking the fuel seems to be pushing out of the carb to intake gasket almost like it's not being sucked in. Any ideas on why?
Offline FlatBlack77
Re: Guess the sound
« Reply #16 on: May 19, 2015, 10:14:34 pm »
sounds like you may have flooded it pretty badly.
getting spark?
maybe you bumped a wire replacing the starter
Re: Guess the sound
« Reply #17 on: May 19, 2015, 10:56:10 pm »
yes it does have spark. And my dad tried to start it when i was at work and it was still seeping out of the gasket/ mixture screw
Offline enaberif
Re: Guess the sound
« Reply #18 on: May 19, 2015, 11:28:56 pm »
If fuel is seeping anywhere then its probably flooded or requires a rebuild. Also if fuel is flooding out of the carb chances are you will need to do an oil change.
Re: Guess the sound
« Reply #19 on: May 20, 2015, 08:51:35 pm »
  I did a dry compression test here's the results (average)
#1 -70 psi
#2-0 psi
#3- went from 100 to 10 psi
#4-0 psi
#5-110 psi
#6-0 psi
And there seems to be a little bit of coolant on the transmission bell housing
Offline enaberif
Re: Guess the sound
« Reply #20 on: May 20, 2015, 09:02:50 pm »
Did you do the compression test with the throttle wide open? Those numbers seem extremely low.
Re: Guess the sound
« Reply #21 on: May 20, 2015, 09:06:42 pm »
No throttle is closed as far as I know
Offline enaberif
Re: Guess the sound
« Reply #22 on: May 20, 2015, 09:25:01 pm »
Throttle needs to be wide open to do a compression test otherwise the results are null.
Re: Guess the sound
« Reply #23 on: May 20, 2015, 09:27:36 pm »
Are the numbers repeatable, cylinder-to-cylinder?  Cylinder 3 changing from 100 psi to 10 psi hints at a compression gauge malfunction.
Re: Guess the sound
« Reply #24 on: May 20, 2015, 09:44:40 pm »
I'll have to re test it in the morning
But I re ran a test on 1 and 2 because the high idle was on and still got the same numbers
Re: Guess the sound
« Reply #25 on: May 20, 2015, 09:51:30 pm »
What do you mean the high idle was on?  Did you start the engine to check compression?  Does the engine start now or do you mean the throttle was held slightly open while cranking?
« Last Edit: May 20, 2015, 09:54:18 pm by bd »
Re: Guess the sound
« Reply #26 on: May 20, 2015, 09:52:10 pm »
No it was set so the throttle was open a little
Re: Guess the sound
« Reply #27 on: May 20, 2015, 09:57:08 pm »
lol.  You answered my question before I finished posting it.  Recheck the compression to make sure you don't have a pressure relief valve leaking on the gauge.
Re: Guess the sound
« Reply #28 on: May 20, 2015, 11:36:25 pm »
Will do 1st thing in the morning. Also picked up another valve cover gasket just incase I have to pull it off
Re: Guess the sound
« Reply #29 on: May 22, 2015, 08:09:54 am »
besides the gauge might be faulty, im not at all familiar with the I6 whats the common factor between the even cylinders vs the odd?
